Old 05-26-2019, 06:32 AM   #1
Fastway E2 Hitch Round Bar L Bracket Wear
I have 2018 (older style) Rockwood 2509s and a 2017 F350 CC SRW. First time out this year and haven't changed anything from last year.
After I got to the campground and removed the Round Bar from the Driver's Side I noticed this.
Any ideas why it would wear on one side like this? The other L bracket doesn't look like this although it has a little wear.
Thank you
posservice is offline   Reply With Quote
Old 05-26-2019, 06:49 AM   #2
IchLiebeBier's Avatar
If you look at the setup from the side, is the bar fairly parallel to the frame, or does it go up at somewhat of an angle?
If it's parallel, maybe you have a loading imbalance of some kind, since it only did it on one side.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
IchLiebeBier is offline   Reply With Quote
Old 05-26-2019, 07:39 AM   #3
Thanks. I'll check when I hook them back up but they were fairly parallel if I recall.
Old 05-26-2019, 07:44 AM   #4
Could there have been sand or dirt trapped. While I canít remember if I was supposed to or if I choose to but I always had small amount of grease. Shop teacher always said where moving metal meets we needed to grease. Perhaps you did just cleaned it up for pic.
moose074 is offline   Reply With Quote
Old 05-26-2019, 08:24 AM   #5
There wasn't any dirt or sand. That's a pretty deep galling. Not supposed to grease those
Old 05-26-2019, 10:04 AM   #6
I have a very similar setup; 2902WS with a F250 SRW. My E2 was doing the same thing. The spring bars are tempered to give them, well, 'spring'. They are harder than the brackets and the brackets will wear. That's part of the design, the brackets are somewhat sacrificial. As IchLiebeBier mentioned, make sure the spring bars are parallel. This will not only spread the wear over a larger area and slow it down, but it may also increase the sway effectiveness. I've seen some plastic snap-in wear plates on Amazon and I've been tempted to try them but I think they will reduce the sway control friction.
2019 Rockwood 2902WS
2019 Ford F250 4X4 CCSB 6.2 4.30
woo10-210 is online now   Reply With Quote
Old 05-26-2019, 10:55 AM   #7
jeff64's Avatar
The wear pattern suggests a tilted installation. With a round bar vs. a square bar as in an equalizer system, the load is borne by a straight line at point of tangency to the point, literally point of contact on the bracket until this wear condition progressed. Just my take!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-26-2019, 11:37 AM   #8
Thanks all. I'll see about some adjustment and check with Fastway also.
Old 05-26-2019, 02:04 PM   #9
That seems excessive on one side as said it could be a set up problem. I found with my Fastway L brackets would shift no matter how tight they were mainly because the bracket set out from the backing plate and the nuts would dig into the bracket, this could be part of your problem the L bracket is loose. My brackets seem to wear fairly even but when you have metal against metal it's going to wear. On my last trip one of the hanger bolts broke off and it could have been from over tightening them, they say 70lb torque. Fastway and Equal-z-er are made by the same company so I called them and they said I could use Equal-z-er hangers on my E2 setup. I just finished replacing them last week and the L bracket tightens up to the backing plate a lot tighter. I bought the hangers from E Trailer being the best price and free shipping.
ID:	205537   Click image for larger version
ID:	205538   Click image for larger version
ID:	205539   Click image for larger version
Werk is offline   Reply With Quote
Old 05-26-2019, 02:22 PM   #10
One other thing you could rotate the L brackets because they do seem to wear on the front side.
hitch
