Old 07-25-2019, 03:52 PM   #1
Rockwood 2715VS owner
Fifth wheel for 2018 ram 2500 diesel
We're pulling a Rockwood 2715VS Ultra-V with our 2018 Ram 2500 Longhorn (6.7L Cummins, A/T, Crew, 4x4 shortbed), and are wanting to move up to a fifth wheel for more room and storage and 4-seasons camping.
Anyone having satisfactory results with a Forest River 5-er and this tow vehicle?
Thanks!
Tom
tlparris is offline   Reply With Quote
Old 07-25-2019, 04:52 PM   #2
NMWildcat's Avatar
Guess I'm not sure exactly what you are after.
There are tons of 3/4 ton diesels out there pulling fifth wheels. I'm sure a lot of them are the same as your truck. Just determine what weights are in your range and stick to that when looking at potential fifth wheels.
Any specific questions?
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 07-25-2019, 05:16 PM   #3
Thanks!
Tom
I wasn’t clear. Specific models in the Forest River lines.
Thanks!
Old 07-25-2019, 05:30 PM   #4
open your door and check your payload sticker. that's a good start. No such thing as a 4 season camper, extended season or 3 season at best.
Kimber45 is offline   Reply With Quote
Old 07-25-2019, 05:36 PM   #5
Fulltime family RVer
I'm willing to guess that a majority of the Forest River lines aren't 4-season rated. RiverStone is the only one that I would guess is.
I can tell you that for certain neither my Sabre nor Spartan are after having both in mildly cold temperatures (what some would call cool!).
Old 07-25-2019, 07:04 PM   #6
I think that would depend where you spend winter. Pretty much any camper is a 4-season camper in Florida. ;^)
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
Old 07-25-2019, 07:07 PM   #7
good point. not in Michigan. prob has a payload about 2500 pounds? minus people and gear pin weight max about 1500-1700?
Old 07-26-2019, 08:30 AM   #8
Better watch the pin weight, my truck has a cargo rating of 2400lbs.
A byproduct of the rear coil suspension.
Upgrade to a leaf spring 3500 Ram if you want a 5th wheel.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 07-26-2019, 12:26 PM   #9
Jim34RL's Avatar
OK this is HERSEY to all of the weight police out there in the either land of the internet.
I do not worry about payload at all. What I look at and stay at are axle loads and tire ratings. My tires on my 2500 Ram Mega CAB 6.7L diesel, are aftermarket tires they are Nitto Dural Grappler tires LT285/70/17 with a load rating of 126 and a speed rating of S. Which means the tires can support a load when inflated to 80 PSI of 3750 LBS each for a total weight of 7,500 on the axles. I run the tires at 70 PSI rear and 55 PSI front when towing. The 70 PSI will support a load of 3415 LBS each which for me is more than enough for my trucks towing needs.
I am towing a 2016 Cedar Creek 34RL, but I do not carry any fluids such as water and waste when towing. This is where most of the weight can occur for an example my tanks are each of 40 gallons, I have 4 tanks. When the water tank is filled up this would mean 332 LBS of weight. Or if all 4 thanks were full this would be approximately1,328 LBS of weight that I do not need to carry. I have weighed my trailer and truck and I am safe on my tire loads and axle loads. This is all that matters to me.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 07-26-2019, 01:06 PM   #10
Grammar Pedant
67L48's Avatar
I also am not entirely sure what the OP is trying to get at. In a general sense, I think the 3/4 ton diesel is among the most popular TVs for 5th wheels here and on the road. So, from that perspective, tow away.
As mentioned above, the 3/4 ton diesels are almost always payload limited, with published ratings in the low 2,000s (check the door jamb sticker). There are several arguments why this payload rating doesn't matter, with some of those arguments better than others. Or, you can do as described above: figure out which ratings you meet, decide that those are important, and then disregard the others (payload, GVWR) that you might be exceeding.
Either way, the 3/4 ton diesel is probably the most popular TV for normal sized 5th wheels. For 43' Toy Haulers and such (big, heavy, 3,000+ lb pin weights), then probably duallies are more popular.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 07-26-2019, 01:09 PM   #11
All well and good for you but hopefully you weighed with all those tanks full and still safe on your loading weight.
I would not want a combination where I couldn't carry full tanks or fluids.
We camp lots of places besides full hook-up campgrounds so being able to carry full tanks and whatever else we decide to take along is a must.
Some folks like to skirt by from full hook-up campground to full hook-up campground not carrying anything. To each their own. One blanket doesn't cover all. Every person's camping needs/experiences/equipment are different.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 07-26-2019, 01:50 PM   #12
Iwannacamp's Avatar
I am not a member of the "weight police", but I highly recommend you at least try and comply with the restrictions of your truck. It is sad that a "big ole" truck like ours have a "little ole" puny cargo capacity. I have seen cargo on later Rams as low as 1700#...pitiful.
I was limited to my 5er and feel certain I am over on pin with a 10K trailer as it is lighter than my old unit, but feels heavier when lowering the landing gear.
Just be cautious when selecting
2017 Puma 297RLSS
Old 07-26-2019, 02:04 PM   #13
You need to know what you want. For now, you can tow 17,000lbs. I am towing around 11,000 lbs right now and it’s nothing for my 2500 RAM diesel
Hman0109 is offline   Reply With Quote
Old 07-26-2019, 02:06 PM   #14
Global Nomad
Scheinin's Avatar
My Cedar Creek is, but OP's truck could not pull it.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 07-26-2019, 02:13 PM   #15
towing 5er with short bed PU
I've heard stories about front of 5er hitting rear of cab because of short bed truck....
thom125 is offline   Reply With Quote
Old 07-26-2019, 02:36 PM   #16
Old Bleu's Avatar
We tow our Cedar Creek 33IK with a ram 2500 with no problem. We use the Andersen Ultimate hitch, and last night I installed a Morryde pin box.
Don't know if you would consider this a 4 season camper, but we were cozy in Asheville, NC when the temperatures were in the 20's.
2019 Cedar Creek Silverback 33IK
2016 RAM 2500 Laramie Cummins Turbo Diesel
Old Bleu is offline   Reply With Quote
Old 07-26-2019, 02:39 PM   #17
I've been towing 5th wheels with short bed trucks for over 25 years.
Never once hit the cab. I guess I'm either lucky or I don't turn sharp enough to hit.
Old 07-26-2019, 02:50 PM   #18
Iwannacamp's Avatar
Or both...
short bed here and dents.... it can happen. In defense to me and truck it was my first camping trip. Now it is a priority.
2017 Puma 297RLSS
Old 07-26-2019, 03:39 PM   #19
NMWildcat's Avatar
Yep, it can happen if you aren't paying attention to everything at once (happens to all of us), and/or you don't have the right hitch for a 6.5' bed. The best solution is a Sidewinder type pinbox. Other solutions are sliding hitches and Anderson types.
I will always prefer 6.5' beds, but I also ensure my hitch setup allows me to turn 90° so I don't even have to think about it. One less thing to worry about
Old 07-26-2019, 03:50 PM   #20
Prime Time Crusader and Dodge Diesel
This combination pulls great. 295RLS
Blair G is offline   Reply With Quote
500, diesel, fifth wheel, wheel
