Old 02-03-2016, 09:27 AM   #1
fifth wheel hitch
new to the 5w community. need info on the pull rite 16k super glide hitch. I run a 2014 ram 2500 with pucks for hitch and also with air bag leveling system. also looking at a reese 20k fixed hitch which will fit into the pucks. any info will help.
reb10163 is offline   Reply With Quote
Old 02-03-2016, 09:44 AM   #2
Left Coast
What kind of info?
Old 02-03-2016, 11:59 AM   #3
Chewie's Avatar
I have a rail mount adaptor to fit the puck system if you interested. Fits Ram trucks only.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 02-03-2016, 12:08 PM   #4
AquaMan's Avatar
And I have a Curt 20K hitch to go along with Chewie's puck rails.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 02-03-2016, 10:43 PM   #5
I have this hitch in a F350 short bed. Can't beat it and never have to worry.
Signguy71 is offline   Reply With Quote
Old 02-08-2016, 11:54 PM   #6
I have the 18k hijacker autoslide in my 2015 ram 2500. I use the standard rails because I don't have the puck system. No problems.
Junior25k is offline   Reply With Quote
Old 02-11-2016, 08:21 PM   #7
C
fueller is offline   Reply With Quote
Old 02-13-2016, 11:45 PM   #8
I have used a 16k pull rite since 2010 without any problems. This hitch does require a little more maintenance. The only con to me is you must be in line and not more than 10 degrees off center to hook up or un hook. Once you get used to that no issues.
Rich5117 is offline   Reply With Quote
Old 02-14-2016, 07:27 AM   #9
tugboat369's Avatar
I think PullRite is a good hitch but. http://www.forestriverforums.com/for...ad.php?t=96991
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
Old 02-14-2016, 09:42 AM   #10
fifth wheel hitch
Tugboat369, I remember reading that post and have to say that was my first thought that the required maintenance might not have been done so well, one of the good things to note that while the capture plate failed, the way the hitch captures and surrounds the pin did not fail and drop the Rv. Every time a post like this is made makes me even more proactive. That being said I trust the Pull rite hitch as I know how it is being cared for. Unfortunately accidents do happen there have been other post that can be looked up as well that have dropped the Rv on the truck even when secured and locked, or a bolt fails and the hitch twist on the truck bed, that was a bad one! Guess the goal is to find a hitch that you are comfortable with that you know how to operate and care for, and hope like heck nothing stupid happens.
Buy the way the original WD40 is not a good lubricant, I know this will get comments, but if you read the background on WD40 it is a water displacement product. I use it often it cleans and gets rid of moisture, then follow up with a better lubricant such as silicone or an oil based product.
Old 02-14-2016, 10:14 AM   #11
tugboat369's Avatar
I agree I still like and use the PullRite hitch. They told me to use WD40 I myself like PB Blaster we use that work. My problem was lack of a weld the local dealer was fine and helped me out even though I was not there customer but am now. The dealer even adjusted my tension bolt free for me said it was to loose. Now bangs less on stops and starts you could move with one hand now need two hands and some oumff.
2014 Columbus 320RS
fifth wheel, hitch, wheel
