Old 06-26-2019, 08:22 AM   #1
fifth wheel hitch
SO I pick up our new 5vr on Saturday Morning.. I looked over the hitches and REALLLY wanted an Anderson, But after learning of some warranty conflicts with that style, I settled on a B&W companion. So The GVWR on ours is supposedly 14K its 11.5 Dry and I believe Keystone does include Propane with that weight from what I read. We typically pack light, so I am imagining about 12.5 MAYBE 13.. But will know for sure once loaded up.
So I am getting a Hitch rated for 16K.. Am I thinking good or should I go larger for a bit more safety factor, like an 18K hitch or something?
ronheater70 is offline   Reply With Quote
Old 06-26-2019, 08:28 AM   #2
No need to go larger than the necessary rated weight unless you plan to get a larger R/V
A 18k hitch on a 12k trailer gives you no benefits.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 06-26-2019, 08:43 AM   #3
acadianbob's Avatar
Your hitch may be upgradeable. Our Demco is. 16K upgradeable to 20K.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
fifth wheel, hitch, wheel
