Old 09-15-2015, 08:13 PM   #11
trbomax's Avatar
Well,mine is 6.5" and Ive never come close to the bed rail.I have an 8' box with a 40gal transfer tank in front,with the pump and meter on top of it.At exactly 90 deg left turn, the fuel meter just nicks the cap.This on level surfaces. I would have to have the trailer wheels in a 2' deep hole to hit the bed rails,and yes I tested this to find out. I dug a 2' deep trench with the back hoe and turned thru it.The trailer JUST kissed the bed rail,the hitch box never came close. Thats all I got!
trbomax is offline   Reply With Quote
Old 09-15-2015, 08:13 PM   #12
hrlyguy2's Avatar
I had the rv place lower mine and never had a issue.
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 09-15-2015, 08:17 PM   #13
Trbomax
Its 45 degree angled steel thats hiting the top of the rail.
gtatrans1 is offline   Reply With Quote
Old 09-15-2015, 08:18 PM   #14
hrlyguy2
I eill have to find someone to lower the pin box. Dealer won't do it
Old 09-15-2015, 08:23 PM   #15
trbomax's Avatar
Originally Posted by gtatrans1 View Post
Trbomax
That sounds more like the hitch box on my horse trailer than an RV The gooseneck hitch on horse and equipment trailers have the 45 deg braces. Never seen one on an RV.We need a pic.
Old 09-15-2015, 08:27 PM   #16
hrlyguy2's Avatar
My old 2007 chevy with a lift kit had almost 8" clearance.
My 08 dually only has 5" clearance.Both 8 ft beds .
I only had to move it to the last holes in the pin box that I had left.
Which was only a inch.
Old 09-15-2015, 08:28 PM   #17
trbomax's Avatar
OK,I just had a brain fart.You are talking about the45 deg side braceing, that is part of the trailer frame that the pin box bolts to.These braces are parallel to the rv frame right? Or the drop in the actual pin box ahead of where it bolts to the trailer frame?
Old 09-15-2015, 08:29 PM   #18
hrlguy2
Thank you. I may have to drop the pin box down in order to accomplish my problem.
Old 09-15-2015, 08:30 PM   #19
trbomax
Trying to sent a photo.
Old 09-15-2015, 08:37 PM   #20
trbomax's Avatar
There are a lot of different sized pin boxes.Maybe you need a shorter one(moveing the pin closer to the rv) so that when you turn it 90 deg the whole pin box swings at a radius closer to the pin.A pin box with more drop would help a little,but doing that might get the trailer and tv un level.A shorter (length wise) pin box would reduce the arc that the pin box turns thru in relation to the bed rail,but it would also move the front cap closer to the rear widow of the truck.Do you have room to do that? Its like shuffeling cards!
fifth wheel, hitch, wheel
