Old 09-15-2015, 08:38 PM   #21
muddyrode's Avatar
I have the same problem as i only have 5 inches of clearance but my truck an trailer sit level so i do not want to raise my hitch upon talking to a guy at goshen he had the same problem and we both have pullrite super glide hitchs he tried a lift kit for the hitch but that made his trailer sit high in the front i,m looking at going to a sidewinder king pin good luck keep us updated
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 09-15-2015, 08:46 PM   #22
trbomax
When I pick up the trailer & hitch up, I will be able to tell.
gtatrans1 is offline   Reply With Quote
Old 09-15-2015, 08:50 PM   #23
trbomax
Its behind the pin that get locked into the hitch. I have a trail air pin box. Its the angled piece of steel.
Old 09-15-2015, 08:57 PM   #24
Phat Phrog Stunt Crew
elind's Avatar
I have 6"s between my cover rail and the bottom of the RV. When I exit out family cottage I go up an incline to the narrow road. When I do this my TV will twist when to one side and the RV will drop close to the cover rail rocking from front to back coming close to touching. I have bent down the front of my box once. I found that I need to keep the TV and the RV as straight as possible as I cross over the edge of the road. My next choice is to remove the rails because the cover is not needed when I'm hooked up.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 09-16-2015, 04:33 AM   #25
Elind, trbomax, muddrode
I want to apologize to all that responded to my call for help. I lost connection to my TV, internet, and Wifi. ALL came back 4:00am this morning.
Old 09-16-2015, 04:35 AM   #26
I want to Thank all of you for your input. You gave me some avenues of help.
Old 09-16-2015, 03:44 PM   #27
Jack350's Avatar
One option that has not come up is how I solved the same issue on my rig. I raised my fifth wheel by installing the Correct Track System. This raised the camper 2 inches, solved clearance issues and gave me the ability to align my axles if needed in the future.
2012 Crusader 26RLD, 2017 F-350 4X4 6.7.
Hayes Autoformer, Correct track, Maxxis 8008E, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 09-16-2015, 04:03 PM   #28
Jack350
What do mean by Track System?
Old 09-16-2015, 05:38 PM   #29
Jack350's Avatar
It is a kit that installs on your suspension that makes axle alignment possible. The bolt on kit does raise the camper 2 inches that in my case helped level the whole rig when hitched. I installed the kit just for the lift but it will allow future axle alignments if needed. Purchased on amazon. Search on You Tube for pictures.
Old 09-16-2015, 05:42 PM   #30
Jack350's Avatar
Here is a picture of the Correct Trac installed.
fifth wheel, hitch, wheel
