Old 09-16-2015, 05:47 PM   #31
Jack350's Avatar
Here is a picture with the truck.
2017 Open Range RES 347, 2017 F-350 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 09-16-2015, 05:49 PM   #32
Jack350's Avatar
Here is a picture connected with truck.
Old 09-16-2015, 06:38 PM   #33
Jack350
Thank you very much for the picture. Now I understand.
gtatrans1 is offline   Reply With Quote
Old 09-16-2015, 06:41 PM   #34
Jack350
The dealer knows how to install trac? If so, they never mentioned this concept.
Old 09-16-2015, 07:13 PM   #35
Jack350's Avatar
Most of my modifications have been found doing research on forums and other sources. My aluminum Andersen hitch is rarely mentioned and is a great way to pull a 5er. 32 pounds and I can lift it with one hand. Rated at 24,000 pounds and really easy to hook up.
Keep looking around and you will find all kinds of great equipment.
Old 09-16-2015, 07:15 PM   #36
Jack350
Thank you very much
Old 09-16-2015, 08:12 PM   #37
heavyodie's Avatar
Some hitches have too much side to side movement. I had a pullrite that was like that and I ended up welding 1/2" steel under each side of the head to limit the side to side movement. Solved my problem.
heavyodie is offline   Reply With Quote
Old 09-16-2015, 08:14 PM   #38
Heavyodie
Thank you. I will look at this aspect.
Old 09-16-2015, 11:04 PM   #39
I have the same setup, except me truck is a 2011.
Me hitch is all the way down and the kingpin (trail air, the one with the air bags) is all the way up.
I have a long box with a flip cover.
I have about 6 to 7 inches clearance between top rail of the truck and the
overhang of the trailer.
The trailer is slightly nose high, 38 feet trailer length, measured front and back to road surface, about 2 inches higher in the front.
I hope this helps.
If you really nose high, the only correction you can do is install bigger rims/ tires on the trailer.
I'm thinking to replace my present trailer tires with LT Michelins next year, they are about 1" bigger in their I diameter, that should help me to compensate the level of the trailer.
wamafi43 is offline   Reply With Quote
Old 09-17-2015, 05:10 AM   #40
Wamafi43
It did not dawn me, but raising the trailer may give me an inch more; which is about what I need. Thank you.
fifth wheel, hitch, wheel
