05-09-2016, 01:19 AM
Fifth Wheel hitch location
I bought a used drw f350 with rails mounted in the bed. When we upgraded from bumper pull to 5th wheel, the seller gave us the reese 20k slider hitch. Have a lot of bouncing so installed air bags. When I was installing the bags and shocks, I noticed the front rail is inline with the rear axle. This places the hitch almost 8 inches behind the axle. I have only towed once with airbags set at 35psi and towed nice on smooth surface at speeds, but bounced when over concrete ir changing speed.
Do I need more psi in airbags? Do I need to move the rails forward to center the hitch over the rear axle?
5th wheel is xlr 380amp tri-axle.
Thanks for helping!
05-09-2016, 04:22 AM
Is the truck a short or long bed? Just curious, I don't think in either the hitch should be so far back. On my Ram 3500 dually, the hitch is about 2" ahead of the axle.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
05-09-2016, 05:13 AM
The hitch should be in front of the axle.
05-09-2016, 05:56 AM
usually within an inch or so of axle center. Not sure what year your truck is, but looking at instructions for a 2011 and up F350, the rails are a inch or tow forward of the axle center. I'm sure you will notice a big difference when you correct this. http://www.etrailer.com/instructions.aspx?pn=C16424-204
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
05-09-2016, 06:54 AM
It is a long bed. I looked at Google results lead me to etrailer web site. From what I read, the pin should be 2 to 4 inches in front of the axle which means my rails are about 8-10 inches behind where they should be.
05-09-2016, 08:56 AM
Yup, get that corrected and you'll notice less front-end float - especially with the pin weight on that AMP.
When installing, they must not have used the custom brackets - maybe they cheaped-out and used generic angle brackets without knowing what they were doing. On mine, with the custom brackets, it would have been impossible to get the positioning wrong because they only mount to the frame rails one way and then the holes for the rails are automatically in the right places.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
05-09-2016, 11:26 AM
Thanks for helping!
Before going to all the trouble moving the rails, I would contact Reese directly and ask for their input.
05-09-2016, 11:34 AM
When I mounted mine instructions were to set pin 1 inch forward of axle centerline. I have had no problems.
05-09-2016, 11:37 AM
x2
05-09-2016, 11:46 AM
F250 pin sits 3" in front of axel. Seems difficult to mount it that far back
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
05-09-2016, 02:39 PM
Several manufacturers, including Reese, have custom brackets to mount their rails to the F350 that don’t require any drilling in the frame. They use existing holes and simply bolt on. As DaveSchwartz said, they must not have used the custom brackets designed for your truck or simply installed them wrong.
The front rail’s mounting slots are ~57” forward from the rear of my truck’s bed, which leaves the pin an inch or two forward of the truck’s axel. As you surmised, your rails aren’t properly mounted.
My truck is a single rear wheel F350 long bed with Air Lift air bags. It was a little tricky mounting the rail brackets with the already air bags installed. Your air bags may present a problem with mounting the rail brackets. You might need to contact your air bag manufacturer to ensure compatibility.
Since the hitch given was a Reese, the rails are most likely Reese rails but not necessarily. As biznsa recommended, contact Reese, a local hitch installer or perhaps etrailer for advice.
It may be best to install custom brackets from a new rail kit and avoid further drilling in the frame as well as the delays trying to make do with the existing kit can cause.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
05-09-2016, 03:26 PM
jb you are correct the pin should 4 in. in front of center of axle.
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
05-09-2016, 06:40 PM
get the correct brackets to mount rails to frame and there is no way you will put it in wrong location.
05-09-2016, 09:46 PM
I have installed all my own 5th wheel hitches, one chev and two dodges and all directions told me " on center(the rear axle) or three " in front. As of time of writing I have had no problems with this configuration.
05-10-2016, 04:14 AM
2007 WildCat 32QBBS
On the Fords the universal rail mount hitches end up being 2 inches in front of the axle centerline. The rail bolts will capture the cross member underneath. If it's an inch to far back or to far forward the bolts will end up in the cross member making it impossible to get a nut on it.
05-10-2016, 05:37 AM
Great idea probably were not available when the original owner installed the rails. Wish they had them when my rails were installed. Try here this is not for your truck you will need to look for that, but here is some good info...........
http://www.hitchpro.net/application/...ons/n50054.pdf
Good Luck
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
