Old 06-07-2019, 01:53 PM   #1
RE retired Fire
fifth wheel hitch question
I'm in the process of purchasing a 2020 Rockwood ultra lite 2650ws fifth wheel, to be pulled by my f-350 6.7. My thought is installing a B&W turnover ball gooseneck hitch with a Anderson 3220 gooseneck 2 connection version. My reason is that i'm over 70 and not as agile and strong as when I was younger. I don't have ready available help to move the heavier hitches so going with the Anderson hitch seems like a reasonable choice. Any and all feedback is appreciated.
Relder is offline   Reply With Quote
Old 06-07-2019, 02:35 PM   #2
I set up a chain fall to lift my hitch out of my truck. Then it gets put on the wheeled cart and put in a corner of the garage.
HDGoose is offline   Reply With Quote
Old 06-07-2019, 03:54 PM   #3
Fulltime family RVer
I’ve had a B&W Companion for almost 6 years. I upgraded campers to one that was higher than my B&W was rated for and got an Andersen Ultimate.
I had the Andersen for 4 months.
It was more difficult to hitch up and the ride for my truck/trailer combination was terrible. It hurt my wife’s back to the point she was in tears on back to back drive days.
I ended up with a stupidly expensive and obnoxiously heavy TrailerSaver TS3. I just leave that one hanging from the kingpin the times that I needed it out of the truck bed.
I would go back to a B&W Companion in a heartbeat. It comes out of the truck bed in 2 pieces. They’re manageable but the base is a bit awkward.
Old 06-07-2019, 05:56 PM   #4
RE retired Fire
Thanks for your reply, I've thought of that but I don't have any free space in my garage.
Old 06-07-2019, 06:04 PM   #5
RE retired Fire
Thanks for the reply, my garage storage space is very limited but I could hang the Anderson hitch on the wall being that it only weighs 35 lbs. I guess my real concern is safety and reliability. Literature says it can handle 16K lbs and a tongue weight of 4500 lbs. The 2650ws will top out around 9k fully loaded with the tongue weight between 1250-1400 lbs so it should handle it?
Old 06-07-2019, 06:31 PM   #6
Canadian Member
If you go with them Andersen Ultimate 2, just remember to lock out the Turning Point pin box.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
itat is online now   Reply With Quote
Old 06-07-2019, 07:17 PM   #7
RE retired Fire
The dealer where I'm purchasing the fifth wheel told me the same thing, so thanks.
Old 06-07-2019, 07:44 PM   #8
Daycruiser's Avatar
Do you really want to void your Lippert chassis warranty on a brand new trailer? If you really want to do a Goose Ball then please get a Reese Goose Box pin box instead.
44 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is online now   Reply With Quote
Old 06-07-2019, 07:54 PM   #9
Oaklevel's Avatar
Many threads on this topic .
But I use the tractor that I mow with to lift my Reese hitch in and out of the bed.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 06-07-2019, 09:33 PM   #10
Understandable. I always kept mine on a furniture dolly so I could roll it around.
I have a couple of acquaintances who have had their Andersens bend a bit. One was on his second and both bent; he was going to have Andersen send him a third. Another guy got a replacement and promptly sold it and went with a B&W. Of course, there are also the widely publicized failures (one with a Grand Design and another that was absolutely destroyed during an accident).
Like I said, I only used it for about 4 months on my 21k fifth whee with 3,400 pounds of pin weight. I never felt unsafe, though mine did rotate in the bed by an inch or so. I followed the torque procedure identified in the manual. I spoke with other owners who said that they thought you were supposed to retorque the bolts after the weight of the fifth wheel was on the hitch. Seems a nightmare to climb into the truck bed. Andersen sort of did and didnít confirm that process in email to me. Honestly, I was left more confused by their emails.
BUT- one thing I liked about the Andersen is that if youíre hitched, youíre hitched. Thereís no chance of dropping the fifth wheel. If itís on the ball and even if you forget to lock the pin, I canít fathom how it would come off the ball.
The need for safety chains is iffy; Andersen says theyíre not required but I didnít want to come across some cop in Bumpkin, Nowhereville and argue it.
Old 06-07-2019, 09:41 PM   #11
BandJCarm's Avatar
I dunno, maybe drive about 70 mph on I-40???
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 06-07-2019, 09:52 PM   #12
robbiels7's Avatar
I will put my two cents in but reading your post it may not be the best option. I have the Blue ox diamond gooseneck hitch which I personally love! Now because the fact that it is harder to hookup 1 having to hook the chains and the e brake cable. Maby I skipped a head a bit far but my pin box is the Reese goosbox. Which is fantastic in my opinion. I just like having my bed available at any time. That would be the chains and cable for the brakes.
Any how good luck with your decision and safe traveling!
robbiels7 is offline   Reply With Quote
Old 06-08-2019, 11:09 AM   #13
RE retired Fire
After considering all of the feed backs and reading as much info as I could find I've decided to use the B&W goose ball and the latest version of the Reese pin box. No voided warranty and a clean truck bed when not pulling the fifth wheel.
Old 06-08-2019, 11:36 AM   #14
robbiels7's Avatar
You will like it.
Old 06-08-2019, 12:20 PM   #15
Telstar's Avatar
If you donít need a slider take a look at Pullrite, they have the lightest 5th wheel hitch. I have a 2018 Ram 3500 short bed so went with the Demco Auto Slide. Weighs over 300 lbs, Iím 75 and only use truck for towing so donít plan on removing hitch. Iíll get help when itís time to grease.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 06-08-2019, 01:12 PM   #16
I have a Reese 18k Elite in my F-250 long bed. I got the "removable" hitch because, like you, I wanted to be able to have a clear bed when not RVing. Worked fine in my 60s, but now that I'm 76 I can't pull it out without more pain than I want. So in it stays.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 28 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 06-08-2019, 04:25 PM   #17
I have a long bed Chevrolet(8 ft.), Reese 16K hitch with rails. When I want to remove the hitch from the truck, I removed the four pins that holds the hitch to the rails, raise the front of 5th wheel until the hitch clears the rails and drive out from under it. On installation, it is just the reverse of removing it. Simple procedure, no lifting or straining on my part and does not hurt the trailer hanging there. Some may say that this puts a strain on the trailer, I say that if it can with stand towing a 10,000 lb. load, then it can support 200 or less pounds hanging on it.
Walholler is offline   Reply With Quote
Old 06-08-2019, 11:22 PM   #18
As far as I have seen on this forum, all have said that any ball hitch requires chains. I believe that it is probably state law in a lot of states.
SQROOT is offline   Reply With Quote
Old 06-08-2019, 11:37 PM   #19
CaptnJohn's Avatar
Having had a few 5er hitches I finally went to the B&W slider 3 5ers back. Will be using a new F350 dually long bed, but keeping that hitch even though no slider needed.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 06-09-2019, 06:53 AM   #20
I have had two fifth wheels in the past that Iíve used a Reese hitch. This time like you I have gone with Anderson for weight and ease of connection. So far it is definitely the best hitch. It pulls so much better and it is so quiet. It is the easiest to connect. No more slamming the pin onto the hitch plate. You can see it out your back window and back under it then drop the 5th wheel on it.
Good luck with it and enjoy!
Barry Elmore
2018 Crusader Lite 29BH
56barelm is offline   Reply With Quote
fifth wheel, hitch, wheel
