Old 12-13-2015, 03:03 PM   #31
5er_tom's Avatar
I have the Super Hlide auto slider
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is online now   Reply With Quote
Old 12-13-2015, 03:10 PM   #32
5er_tom's Avatar
Sorry to continue. I have the Super Glide auto slider. Before that I had a Reece Revolution. I will say I do not think I have ever been in situation where the slider was necessary, and I have put a lot of miles on the two 5th wheels, in and out of a lot of campgrounds.
But, I do sleep easy at night knowing that if I do something foolish or stupid, the slider will prevent me from RV/TV contact and the large chunk of change to repair.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
Old 12-13-2015, 03:17 PM   #33
Kenny kustom's Avatar
Originally Posted by redjet View Post
kenny you may have missed AUTO (autoslider)
Glad you corrected it!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-13-2015, 03:53 PM   #34
Originally Posted by Windy View Post
Just purchased a Cardinal 3250RL fifth wheel. I have a 2015 F250 4x4 SuperCrew, diesel, with a 6 1/2 box with the factory installed fifth wheel hitch prep (puchs system). I am considering the Demco 18k auto slider (only one I could find that fits the puchs) or the B&W Companion 20k fixed for the puchs system. My main question is "do I need a slider hitch "? Would appreciate comments from F250 owners with the puch system pulling a fifth wheel and what type of hitch they recommend? Thanks!
I have the Cardinal 5th wheel with F-350 I have a Reese 18K Elite with the pucks hook up my truck is a short bed I'm looking to buy the Demco Autoslide but can't find any dealers who would take my new Reese in on a trade in. But I have almost taken out my window several times. So it's time and I find Demco's got about the best I've seen.
selkirk awards is offline   Reply With Quote
Old 12-13-2015, 04:58 PM   #35
Towing capacity
I just checked weight of your trailer (14K+) and towing capacity of your truck, I believe you are pressino the limit of your SRW. Diesel 2015 TV. (14K). I believe your truck will tow it, but I would be real careful how you load it. You don't have any extra to cover passengers, regular gear and water in the fresh water tanks. I have a CC 38FL, and I went larger with DRW.
I had a 2002 Chevy. Duramax. 2500 diesel SRW, short bed with a slider to pull my former 5th wheel, but never used it. I just watched the trailer and truck as I backed in and was real careful. Although the new CC was over 16,800 lbs empty, my old truck would pull it, but I was worried about reliability while we traveled because of age and overload, so a got a newer larger one. Also did not want to get sued if in an accident.
numbersman is offline   Reply With Quote
Old 12-13-2015, 05:35 PM   #36
MtnGuy's Avatar
A big downside with a autoslide hitch installed is that only someone with a slider hitch can tow the trailer. This is because of the adapter plate that must be installed on the MorRyde. Behind the kingpin there is a puck welded to the plate that in effect operates the autoslide. The adapter plates are even different between pullrite and demco. So no-one with a standard hitch can tow your trailer and you cannot tow a standard pin box.
With a Demco autoslide hitch, doesn't the hitch "capture" the pin box on each side, instead of using a capture plate on the pin box ?? If that is so, then there is no pin box alterations needed, and that trailer could be pulled by any 5th wheel hitch....except a SuperGlide, which need a capture plate.
Old 12-13-2015, 05:43 PM   #37
You are exactly right. That is exactly why I chose my Demco autoslide. I can tow any trailer that doesn't have an air ride pinbox. Anybody else with any other standard FW hitch can hook up to my trailer.
rmoore0852 is offline   Reply With Quote
Old 12-13-2015, 06:11 PM   #38
Originally Posted by GreenImp View Post
Short Beds without sliders don't dent cabs....DRIVERS of Short Beds without sliders dent cabs.
In my opinion, the drivers abilities are far more relevant to whether or not you should have a slider than what truck/trailer you have.
I'm a bit offended by that comment. I have been pulling trailers for years, including permitted oversize/overweight oilfield equipment. One of our driver tests is a slalom course with an 18 wheeler, IN REVERSE! Basically, I know very well how to back a trailer. Just like anything else, the slider is a tool that has its place. There are times that the best driver in the world cant overcome the physics of how tight a turn you have to make vs the limited clearance of a short bed pickup. I knowingly chose a short bed truck, knowing that I would need a slider to safely pull my trailer. To me, the autoslide just takes any worry out of it. Turning into a gas station with a drainage dip in the middle of the turn? No problem, no worries about the dip letting the trailer hit the window. I put my trailer in my driveway while packing and unpacking. Considering the width of my street and driveway, I have to have a slider to make that turn. With an autoslide, I don't have to get out of the truck. Just pull up, shift to reverse, and back it in. We dry camp in the national forests a lot. I like being able to turn around in a clearing on rough ground without worrying about damage.
Bottom line, I believe that a slider is a tool that has its uses. If you choose to not use one with a short bed and never damaged your truck, good deal. I like being able to just drive, and not be watching bed clearance all the time. Takes some of the stress out. Sorry about the rant and if you didn't mean any offense, then no worries. Just please understand that just because YOU have never been in a situation where a slider was absolutely necessary, DOES NOT mean that those situations don't exist.
Old 12-13-2015, 07:19 PM   #39
I was under the assumption that all short bed trucks need a slider hitch! (Isn't that true?) This is my first FW so I may be wrong about that.
That is why I bought the Pullrite auto slider for my 2015 GMC 3500 crewcab. I am pulling a CC 36CKTS and love the auto slide and I can feel it slide at almost every turn I make.
2015 GMC Denali 3500 4X4 Duramax
2015 Cedar Creek 36CKTS (flooded 2-20-18)
2019 Cedar Creek 36CK2 (picked up 5-1-18)
grumpyoldman is online now   Reply With Quote
Old 12-13-2015, 07:43 PM   #40
Is it needed, no. Is it a nice to have more carefree option, yes. Your autoslider goes back on every turn because it's designed to do just that. Not because ever turn has the potential to cause truck to RV impact.
Karl4Cat is offline   Reply With Quote
fifth wheel, hitch, slide, wheel
