Old 12-16-2015, 07:23 PM   #61
CWSWine's Avatar
Originally Posted by Karl4Cat View Post
That's really cool that you can get a full 90 degrees. I could get 88 with my previous 5th but not so much on my current one.
I don't think there is hard fast rule and depends on if you pin is over the axle or a couple inches in front of the axle and how you the nose of the 5er is shaped.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 12-16-2015, 07:26 PM   #62
Kenny kustom's Avatar
The only hard fast rule, is if it hits hard and fast, busted back window and a large dent!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-16-2015, 07:33 PM   #63
CWS, I hear you. It's all in the shape of the nose. My last one was a Heartland product and they went to 88 degree caps on all their lines. I still had to watch as 88 isn't 90 but it was a touch less watching than now with my XLR.
Kenny, that is true. It's also true that if you hit a tree while backing up your rig with a long bed or a slider it will also leave a dent. Not in your rear cab / rear window area but a dent just the same. Bottom line is paying attention is paying attention. Watch your clearance every time and you'll never hit...
Karl4Cat is offline   Reply With Quote
fifth wheel, hitch, slide, wheel
