Old 05-08-2015, 02:13 PM   #1
Fifth wheel running and tail lights
My fifth wheel brake and turn signals work but ny tail lights and running lights don't. Think problem is in truck. All fuses ok. Maybe a relay. Does anyone know how to test a relay.
safrog is offline   Reply With Quote
Old 05-08-2015, 02:24 PM   #2
Witch Doctor's Avatar
What do you mean Running Lights? Marker lights maybe. Mine will blow a fuse every 50 miles or so, FR gave up and said I must be hitting a staple now and then. I put an resettable fuse in my truck for that. You need to put a meter on your plug in on TV and check if it's getting 12 V. Did you check the Tail lights with a meter?
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-08-2015, 02:59 PM   #3
brookstone345sa's Avatar
With tow package there are fuses under the hood also, process of elimination. Start under hood and work back. Make sure your plug is making good contact and not corroded. Try tester at plug on truck and see if you have power there.
brookstone345sa is offline   Reply With Quote
Old 05-08-2015, 03:18 PM   #4
There is a relay for trailer under the hood of my truck. I am wondering if anyone out there know how to test relays. Guess I can get another one and replace it to see if that does to.
Old 05-08-2015, 03:47 PM   #5
Phat Phrog Stunt Crew
elind's Avatar
My GMC had a blown fuse under the hood for my running lights. GM has a fuse box on the drivers side with square cover over it. Pop open the cover and there is a diagram with all the fuses listed. You may be lucky and replace it with no more problems.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 05-08-2015, 07:35 PM   #6
I had an issue with lights once also on my Chevy. There was another fuse box on the left side of the dash that had a blown fuse.
Filthy Beast is offline   Reply With Quote
Old 05-08-2015, 07:52 PM   #7
The only way to test it is your going to have to know what is common, normally open and normally closed. Relays are cheap if in doubt just get a new one. You still need to check the output at the TV first, then the bulbs and then the relay if no power is shown.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-08-2015, 10:42 PM   #8
Thanks. I will just get another relay
Old 05-09-2015, 07:30 AM   #9
2007 WildCat 32QBBS
05CrewDually's Avatar
To check a relay just swap it with a known good one such as fuel pump or a/c.
As far as your lighting, check your owners manual first for ALL fuse locations. The trailer plug should be on its own circuit that's why it still works.
Pull the tail lights and replace the bulb or if you have a meter or test light check for power. For both circuits, tail and brake/turn, to be out it may be a bad common ground.
05CrewDually is offline   Reply With Quote
Old 05-09-2015, 12:51 PM   #10
I have a similar problem with my 2015 Coachmen Prism 24G motorhome. None of the perimeter (I assume what you call running) lights work, nor do the licence plate lights. All the other lights work (brake, backup, tail, turning, head, etc.). I assumed it was a fuse, so I consulted the Mercedes Sprinter "Fuse allocation supplement", which showed a fuse for just that circuit (Fuse #20, fuse block F55/5, located under the driver's seat). Unfortunately, fuse block F55/5 that fuse #20 was supposed to be on was not there (nor was block F55/7). I assume that the other fuses on those 2 blocks are unnecessary for my Prism. I contacted Coachmen service, they have no idea where that fuse may be. They suggested "in the glovebox" but there are no fuses there.
Does anyone have an idea?
jeffrapp is offline   Reply With Quote
fifth wheel, light, wheel
