Old 09-19-2016, 05:33 PM   #11
another_newfie's Avatar
I am actually thinking about removing my Kwik slide and going with stationary legs as I know I can get another few inches that way. My rig has the contoured nose and I've never even come close to using the slider.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 09-20-2016, 02:36 PM   #12
Originally Posted by lesptr View Post
I just got off the phone with Jason at Andersen. He's going to swap out the base with one made for flat bed trucks. This will lower the nose 2 3/4 inches (approximately) which will give me slightly more than 6 inches of clearance between the bed rails and trailer. I hope it's enough. More to come.
When I purchased our SRW 2006 F-350 new, it was too high in the rear. I had the dealer drop the rear 2". There was a TSB from 1999 that still applied to the 2006 model. That was enough to level the 5W. It is important to have 5-6 inches clearance above the truck bed rails (below the front of the 5W) for both turns and entering/leaving fuel stations, etc.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 09-20-2016, 02:40 PM   #13
Another thought - towing the 5W nose high (or low) puts undue weight on the rear or front axle of the 5W. Weight not part of the design of the trailer frame / axles.
Old 09-20-2016, 03:30 PM   #14
jtesta1's Avatar
over height
Truck manufacturers keep building trucks taller to fit bigger tires for better fuel mileage. they don't think about someone wanting to pull a fifth wheel. I chose to lower my truck because it became to unstable . I like it low and slow , much better ride and handling.
jtesta1 is offline   Reply With Quote
Old 09-20-2016, 04:00 PM   #15
That should help a lot and 6" is still OK for rail clearance.
That's about what I have and haven't seen it get close yet.
Remember dropping the nose will also raise the tail so if you come down 2.75" inches in the front the back is going to go up too. Not always 1:1 because of axle placement but you might wind up pretty level.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-20-2016, 04:07 PM   #16
lesptr's Avatar
That's what I'm hoping for.
2017 Coachman Chaparral 334TSIK
2015 F350 PS
lesptr is online now   Reply With Quote
Old 09-20-2016, 04:09 PM   #17
lesptr's Avatar
That's why I'm try to get the rig level.
2015 F350 PS
Old 09-20-2016, 04:27 PM   #18
Mine rides slightly nose high and I was concerned about stress on the rear trailer tires. Using a laser thermometer, I've found that the rear tires consistently run about 5 degrees (F) hotter than the front. Interestingly, while on interstates, the tires on the sunny side run 8 to 10 degrees hotter than the shady side. So far, no problems, but I did replace the load range Cs with Ds.
"But, oh that magic feeling, nowhere to go." -- The Beatles
2015 Flagstaff 8528RKWS fiver
2013 Ram 2500 CTD Laramie CC SB 4WD Auto
cbconway is offline   Reply With Quote
Old 09-20-2016, 05:12 PM   #19
CaptnJohn's Avatar
The 235/85 tires would have raised the trailer almost 1".
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 09-20-2016, 05:42 PM   #20
lesptr's Avatar
Maxxis does not make a tire in that size. I looked into Sailun tires, but no one carries them around here.
2015 F350 PS
fifth wheel, wheel
