11-18-2011, 10:40 PM
Fifth Wheel Trailer Connector
I have a 2011 Dodge Ram 2500 with factory brake cotroller and a 2011 Palomino Sabre. I am constantly getting a message on my dash "Tailer Brake Disconnected" The cable is tight, I still push in the connector as tight as I can. My message goes away. I drive about 30 minutes and get the same message and repeat the same process. Can I please have some thoughts? I'm driving dangerously and need help. Thanks.
Steve
11-18-2011, 11:05 PM
Do you plug your cable in at the bumper or do you have a connection in the truck box.
Todd & Sheila and kids
Rouleau, Saskatchewan
2012 Surveyor SV-305
Dads 2011 GMC 2500 HD
My 1999 Dodge Ram 1500 4X4
11-19-2011, 04:57 AM
I had that issue a few years ago with my old TT. I cleaned up the connectors with a small wire brush and put anti corrosive grease on both connectors. That seemed to take care of the issue.
Wally
2011 Flagstaff 8528RKWS
2009 Toyota Tundra
11-19-2011, 05:46 AM
too fast turbo sled
connections are where I would start.
do the trailer brakes work ? or do they work intermittently ?
or have you even checked ?
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
11-19-2011, 06:20 AM
Lou Amadio
You either have a bad ground, dirty/corroded socket or plug, or or a loose wire in the socket. My money is on a corroded/loose connection in either the socket or the plug of the wiring pigtail.
Use a socket/plug wire brush to polish them up. If that does not work, you will have to do some more troubleshooting. It is unsafe to drive with the indications you have. Most likely your trailer brakes are losing power.
Plug And Socket Scrubber Brush 7 Conductor, 4-121, Phillips Industries
Will clean your pins (WARNING - MAKE SURE THE POWER IS OFF) and the coat with a dielectric grease to prevent corrosion.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 4)
11-19-2011, 08:23 AM
I had the same problem with my Rockwood 5th wheel. Kept losing connection, wiggle the plug and it would work again. Connections were all good. The problem, even though the trailer plug connected into the truck the electrical connections were just not a good match. I bought a Curt truck and trailer plug set, installed them and no more problems.
DRINK COFFEE--do stupid things faster and with more energy !
11-22-2011, 01:00 PM
Dallas Texas
I use the dielectric grease on the connectors on my bike. It keeps them clean and prevents corrosion. I get a tube at NAPA for a few bucks
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 589 |
| 119 members and 470 guests |
| 2000XLifted, 4Jeeperz, 5Galvs, Adony, alphadog99, Andy R, Bandit114, Barney1, bean, bear17, biken201, bikendan, bobbygee, boubou, brookside, Browndog, Busman1947, Cafjackracing, Cascade Bob, cdbus, chiro, chof16, comfun1, cyclepuck, dashonthedash, dasimser, Dave_at_FastwayTrailer, ddavis662, ddemme, dec1952, deerslayer, Deputyseven, DGrissom, DonG, donn, Dukejr, dummin4fun, elind, forthefunofit, FreedomTracker, frfan, gbpacker, GeorgieGirl, Gizzerd, Gman88, Gollum, Happy Vibe, HWII, iscotty123, isz, itat, JamesR, jasni, Jeep4Two, JJones, JoeR, Joker, jphillips1075, jrcouture, jsutherl, jwuertz, J_KHawthorne, kegoneill, kfroe, kjoh75, LFugate, lowbubba, Mad4sax, McLuer, mhartzel, mia, Mr. Legato, mrmurph, MT28rk, mtnguy, NanaKaren, pandkm, pappcam, Pharmofish, PrairieBoy, punkaccountant, pwrplay, Ragin Cajun, Redheaded blue tick, ret2006, rkswyo, rob and lisa, Rogue69, Rsgtivr6, rstewart06, SabreMarv, SabreSam, Sailfish Bret, sbond, shineysideup, SimchaSabre, skippy31405, snowbrid, softwarejoe, southernsky, spike, Steve7575, texashatter, tgarner2000, Tincup13, Titleguy, tking1866, tmmar, torben, Triguy, viper48, VTX Al, wakamicamper, wayne anthony, whj77372, Wichitalineman, william.migues, woodchomper, wvfireboss |
| Most users ever online was 996, Yesterday at 11:04 AM. |
