Old 01-21-2014, 03:40 PM   #1
Figuring out best cruising speed
Hoping you guys may give me some insight into figuring out my most efficient cruising speed.
I have a '14 GMC 2500hd with the Duramax and 3.73 gears. It's a crew cab and will mostly be occupied with about 450 lbs of humans and another 200+\- cargo. My trailer is a 3150bhd weighing at about 10k max.
Is there anyone out there with a similar set-up? Going to be mainly highway on the east coast, and PA can get pretty hilly, so I'll try and make up for that on the straights.
Agewon is offline   Reply With Quote
Old 01-21-2014, 04:03 PM   #2
Oaklevel's Avatar
I told the boys when I taught them to drive a stick the car will tell you when to shift....... I go by the same idea with speed pulling the trailer..... the truck kind of determines how fast but I rarely go over 65. I just go with what ever the MPGs are............ and don't worry about that.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 01-21-2014, 07:29 PM   #3
Chuckinca's Avatar
65 MPH works for me in most open highway flat situations.
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
Old 01-21-2014, 07:38 PM   #4
RKR
RKR's Avatar
No more than 65. Your Duramax will be in it's peak torque at just under 65.
Also, after 65 the wind resistance really kicks in and will effect you fuel mileage.
RKR is offline   Reply With Quote
Old 01-21-2014, 07:46 PM   #5
We like 62 mph on the open road, good for mpg plus most trailer tires are only rated for 65 mph.
Sirsea is offline   Reply With Quote
Old 01-21-2014, 08:45 PM   #6
Fulltime family RVer
Same here.
Old 01-22-2014, 05:13 AM   #7
transamz9's Avatar
My truck really likes 70-72. Like others said, your tires on your trailer are rated at 65.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 01-22-2014, 06:07 AM   #8
AquaMan's Avatar
My 5er is around 14k and it likes 67-68mph. Anything less (62-65), and it feels like it's wanting to downshift, and occasionally does. Each trailer and setup has it's own "sweet spot", just need to find yours.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 01-22-2014, 06:12 AM   #9
I run at 65 mph. It's in cruise and not in tow haul. I do use tow/haul for braking along with the engine braking. We travel across the top of the U.S. going out to western Canada and back the same way. In the foothills of the mountains and just about on any hilly roads we are in cruise and the duramax handles it great. Barely notice when it downshifts to 5th. I have a 2011, 1ton dually, crew cab, long box, 4x4. I use tow haul mode when merging back onto the highway to get up to speed. I've had 2 trucks with the duramax engine. The 1st one was a 2001 3/4 ton and I travelled at the same speed with that one but there is a ton of difference with the newer one. More HP for one. My 5er is 35 ft and when packed for camping and/or traveling out west the total weight for both vehicles is around 23,900 lbs. My tires all around are at 80 psi.
Pipeman is online now   Reply With Quote
Old 01-22-2014, 06:25 AM   #10
Todouble's Avatar
I've always heard you should use tow/haul mode when towing heavy. It provides engine braking and changes the trans shift points. Don't know for sure but was told you can tear up a tranny if you don't when towing heavy. Anyone else know what's correct?? Aside from that I run about 68 mph towing a 12k fiver!
Todouble is offline   Reply With Quote
