Old 11-23-2015, 07:08 PM   #1
Finessing hitch onto the ball
I can't tell you how ignorant I feel about this issue. I've hooked up my Mini-Lite 1901 multiple times. A few times, it's gone perfectly. More times, though, I cannot get the hitch lock lever to go into the lock position. I have a backup camera on the truck so getting the hitch under the ball is not a problem. I am doing this alone so I am in and out of the truck trying to make slight adjustments in position. At campgrounds, I've had to enlist help from fellow campers several times.
The men that have helped me manhandle it into place - kicking, pushing, bouncing. That's how my husband used to deal with it. I apparently don't have the strength or the confidence to push it into place. I know I'm using the right size ball for the hitch.
Are there any tools, tricks, pointers that anyone can offer that can help? Is there any maintenance I should be doing like greasing the ball?
2015 Rockwood Mini Lite 1901
2017 Ford F150 EcoBoost
Terrib972 is offline   Reply With Quote
Old 11-23-2015, 07:38 PM   #2
Most of the time if you just push the trailer towards the rear it will allow the hitch to last.
wanderingbob is offline   Reply With Quote
Old 11-23-2015, 07:50 PM   #3
Crusadernoob's Avatar
After you drop the trailer onto the ball just pull the truck up a couple inches, should latch no problem.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 11-23-2015, 09:42 PM   #4
Terier's Avatar
Ditto. Sounds like the hitch ball is a little far back. When this happens I will put the truck in drive and it will move forward a tad before putting on the brake. No need to give it has.
Old 11-23-2015, 10:56 PM   #5
coupevillefish's Avatar
I like to keep the front edge of the ball just a little forward of the coupler so that the trailer rolls forward a bit as you lower it. Same results as inching forward described above. That helps to assure that the ball does not trap the coupler lever.
coupevillefish is offline   Reply With Quote
Old 11-24-2015, 11:36 AM   #6
MtnGuy's Avatar
I addition to making sure the ball is to the front of the coupler, make sure the trailer tongue is down firmly on the ball, not just partially down.
Old 11-24-2015, 11:41 AM   #7
rsdata's Avatar
X2
carry a rubber mallet and beat on it a little
don't put grease on it just makes it messy
maybe a little WD-40 in the lock mechanism and the ball before hitching
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
rsdata is online now   Reply With Quote
Old 11-24-2015, 11:51 AM   #8
Ditto x 3. I use my trailer often and am either hooking it to my truck or MH. If I can't latch it I just let either vehicle pull ahead an couple of inches. If the ball is off center then I turn my wheel all the way to the left or right. Living with rheumatoid arthritis pretty much means you have to improvise. No different from getting old. lol
Bud Ezekiel H. is offline   Reply With Quote
Old 11-24-2015, 11:57 AM   #9
Stormrider151's Avatar
I position the ball 3/4 under the hitch. As it lowers the hitch will slide over the ball the rest of the way. If the ball is too far back it will get hung on the lock mechanism and not let the hitch all the way down.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 11-24-2015, 12:00 PM   #10
Dave Lyon's Avatar
Me as well.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
hitch
