Old 08-17-2015, 10:39 PM   #21
Blog: RVroadtripper.com
hbillsmith's Avatar
See my sig. The compressor control is wireless. Unit mounted on frame below the passenger side rear door.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is online now   Reply With Quote
Old 08-18-2015, 04:41 PM   #22
Just mounted my Air Ride Wireless One compressor forward of the spare tire. With wireless, no need to mount any controls in cab and it works perfectly.
Gmar60 is offline   Reply With Quote
Old 08-18-2015, 05:41 PM   #23
Send a message via MSN to redjet
Air lift with wireless compressor. Compressor, manifold, etc. mounted on a 8"x10" plate which is mounted in the front wall of the truck bed (very dry and no heat). The truck has a bakflip cover. Wires run to front of truck (2015 F250) upfitter switch. Air lines are short and run out the plastic port to each bag. Works great. Ford/Chevy/Dodge it makes no difference installing the compressor and components. They recommend a dry place away from heat. Easy to get to if problem occurs.
2016 Camping - 181 days
2017 Camping - 194 Days
2018 Camping - 90 Days
2016 Cardinal 3850RL - 7/31/15
2015 Ford F250 - 6.7L - King Ranch - 4X4 - Air Lift 5000/ wireless air
redjet is offline   Reply With Quote
Old 08-18-2015, 06:55 PM   #24
Ford F-250
I put mine on the back wall of the bed ( drivers side ) it's covered by the Retrax cover and box. Looks good and it's not in my way or in the elements.
markoldin is offline   Reply With Quote
Old 08-19-2015, 02:09 PM   #25
MilCop4523's Avatar
we have so much salt and road crap in east Canada that i just went with the airlines placed where the license plate bolts used to be. two caps on them and no one ever notices them there.
and when the 5th wheel is hooked on it is an easy 2 feet to recharge them.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 08-19-2015, 07:46 PM   #26
Originally Posted by jtownstumpjumper View Post
Not familiar with the wireless....Where's the air compressor mounted on your 3500HD?
Mounted the compressor under the truck just behind the transfer case to the bottom of a cross brase under the the floor. A little tight but worked out great.
grayfox is offline   Reply With Quote
Old 08-19-2015, 11:59 PM   #27
I had an 07 GMC and put the compressor on the frame with a plate like one other comment. Drove it for about 5 years and the aircompressor failed. Cost a bundle for another compressor. Now had a 13 Chevy 2500 HD and bought a cheap ($12.00) little compressor from a local Bi-Mart. I plug it into the cigarette lighter receptacle on the dash. I used one line and a "T" so both airbags are on the same line. That way if I lose one bag, I have lost both and am not lopsided. I put a small valve in the fuel tank filler door and fill my bags from there. I found I did not use the compressor that much and decided to buy a new rod and tackle with the money I saved on the small stand alone unit. If the $12.00 compressor fails, no big deal. When the compressor Les Schwab sold me failed, it was several hundred dollars to replace. So far, no big deal to use the small, separate compressor for the bags. As I got older I have moved from more complicated, installed systems to simpler uninstalled systems.
MacII is offline   Reply With Quote
Old 08-20-2015, 08:06 AM   #28
paulj4400's Avatar
Put compressor behind passenger side battery under hood. Seems to work fine.
paulj4400 is offline   Reply With Quote
Old 10-01-2015, 12:11 PM   #29
Busybeavers's Avatar
Nothing against you Ford guys but I hoping for someone with a Chevy or GMC 2500 or 3500HD has done this and will let me know where they put the compressor.....I don't want it inside the truck....btw, where did you put it on the Ford?
Jtownstumpjumper;
Did you ever find a place to mount it?
Busybeavers
2016 CC Silverback 29RE
2012 GMC 2500HD 4x4
Crew/6.5 Bed
Pullrite Superglide
Duramax/Allison
Busybeavers is offline   Reply With Quote
Old 10-01-2015, 01:52 PM   #30
hbillsmith's Avatar
Air Lift WirelessONE Compressor System for Air Helper Springs - Hand-Held Remote - Single Path Air Lift Vehicle Suspension AL25870
The clicky above will take you to a nice eTrailer.com video showing the Airlift one installed on an GMC3500. There are others for the 2500 and 1500. Basically, the compressor is mounted on the passenger side frame, in front of the rear wheel and approximately below where a back seat passenger would sit. The compressor on my 2015 2500HD was mounted on the outer side of the frame.
