Old 10-01-2015, 02:08 PM   #31
Air pump
I have used one in my 2008 Chevy 2500 HD 6.6 . I put the pump in the engine compartment and run the air line along the frame. Had to use a fishline in the box frame. put well worth it.
and the wire went thru the fire wall found a grommet and the switch I put right on the left hand side down low. It was a pump up / deflate switch.
outloud is offline   Reply With Quote
Old 10-01-2015, 09:41 PM   #32
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Originally Posted by Busybeavers View Post
Jtownstumpjumper;
Did you ever find a place to mount it?
Yes....I mounted it on the outside of the frame just under the driver's door.....that allowed for easy access with the hot wire directly up the firewall and straight to the battery under the hood that's directly in front of the fuse box.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
