Old 08-17-2015, 09:34 AM   #1
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
Firestone Ride Rite Air Bag Add-on
I just installed the Firestone Ride Rite Air Bags on my 2012 GMC 2500HD....I think I now would like to add the onboard air compressor kit with control switch for under the dash so I can control air pressure from inside the truck....for those who have done this, where is a good place to mount the compressor...looking for suggestions that have worked best for everyone...thanks.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 08-17-2015, 04:11 PM   #2
I put mine at the bottom of the dash on the right from the steering wheel. I put mine to help out with the bumper pull camper I had at the time, it was not much help
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 08-17-2015, 06:06 PM   #3
Are you talking about the switch & gauge at the bottom of the dash.....I'm looking for a place to mount the air compressor....You have your air compressor under your dash???....Maybe I've misunderstood you....I don't want it inside the truck because of noise.
Old 08-17-2015, 06:24 PM   #4
Dabmeb's Avatar
I found room where the storage box was in the left front fender of my suburban when we had it.
Dabmeb is offline   Reply With Quote
Old 08-17-2015, 06:41 PM   #5
Forbes's Avatar
You will love them, put set on Ford F-350 pulling 36CKTS and it really helps level out TV and RV.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Days Camping 2014-96, 2015-130, 2016-126, 2017-42 and counting
Forbes is offline   Reply With Quote
Old 08-17-2015, 06:51 PM   #6
Thanks for your response....my problem is I have two batteries on my 2500HD diesel and that place you're talking about is taken up by the second battery....I was hoping to locate it somewhere under the hood though.
Old 08-17-2015, 06:55 PM   #7
Nothing against you Ford guys but I hoping for someone with a Chevy or GMC 2500 or 3500HD has done this and will let me know where they put the compressor.....I don't want it inside the truck....btw, where did you put it on the Ford?
Old 08-17-2015, 07:47 PM   #8
muddyrode's Avatar
i,m in the same boat looking for a place to put my compressor but i i,m thinkg about in side the cab i do not see it going off or on very oftenun less you have a leak if any one has put one inside please chime in also
tks sorry if i hijacked your thread
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 08-17-2015, 07:50 PM   #9
Dutchtexan
Dutchtexan's Avatar
I have the Air-Lift air bag system on my 2011 Chevy 1500 and it should be very similar to your system. I mounted my pump under the frame below the passenger side door. Just took a flat piece of metal [late and bolted it to the frame then bolted the pump to the plate. Has been there for 4 years already and no problems with it. Here are some pics of it.
ID:	85987   Click image for larger version
ID:	85988   Click image for larger version
ID:	85989   Click image for larger version
TT: 2014 Forest River 27VRL Super-V
V-nose TT w/Rear Living area, 2 slides, Equal-I-zer 4 point hitch #10000
TV: 2011 Chevy Silverado Z71 Extended Cab AirLift 1000 w/WirelessAIR
Dutchtexan is offline   Reply With Quote
Old 08-17-2015, 08:03 PM   #10
Forbes's Avatar
I never put the compressor unit on, I ran the hose to back of truck and use a small battery compressor and gauge. It really is no problem, once you find your sweet spot.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
