Forest River Forums
Sunline User Photos
Old 05-15-2011, 08:49 AM   #21
hatstomper's Avatar
Originally Posted by hatstomper View Post
Hello all. I'm new to this along with being a new RVer. I have a question that I hope someone can help with. (This is only the first of many I'm sure) Anyway, we have ordered a 2011 Rockwood 8280WS 5th-Wheel with a Reese sidewinder hitch and are going to pull it with our 2008 GMC 2500HD Duramax, 6' 6" box. The dry hitch weigh is shy of 1200lbs and I'm wondering if it would be worth the $700 to put Firestone riderite airbags on the back of the truck?
So now that they are on the truck. What I'm I looking for as far as PSI. Right now with the truck mt I can feel the diff. and the have 9lbs in them.. I realize there are many variables but what does everyone "normally" run them at when loaded???
hatstomper is offline   Reply With Quote
Old 05-15-2011, 11:40 AM   #22
cheese53073's Avatar
measure your front and rear truck height unloaded then run enough air into them to restore a level ride. This may or may not be the same height as unloaded depending upon how your WD hitch loads your suspension.
say for example there is a 1" differential between the front and rear. After hitching up add enough air to return to near this differential. once this is done test drive and adjust as needed.
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
Old 05-15-2011, 01:13 PM   #23
Firestone Airbag Kit
I purchased the Firestone kit without the compressor, installed myself for around $260.00. I use a cigarette lighter air compressor to fill when needed. They are pretty easy to install, if you can pour water out of a boot, you can install them!!!!!!!!!
When not towing my 8285WS, I bleed down to 5 PSI, when towing I inflate to 45-55 Lbs. Sure does improve the ride and levels the TV to the 5 ver.
I failed to see where in Canada you live, but a side trip to the US for a purchase is not out of the picture ????
Sid & HRH- Daisy the Boykin.
2011 ROCKWOOD 8285 WS
2005 F-150 SUPERCREW
SUPER GLIDE HITCH
DAISY BOYKIN is offline   Reply With Quote
Old 05-15-2011, 04:20 PM   #24
You should check your owners info, mine says minimum pressure of 10 psi is needed.
Rockwood 8293RKSS
Old 05-15-2011, 05:49 PM   #25
What brand name of air bags do you have?
I installed Firestone bags on my truck last week and I just checked my manual says a minimum of 5 PSI
Ken & Janet
'07.5 GMC 2500 D/A CC/SB
'09 SABRE 31RETS-6
wingriders is offline   Reply With Quote
Old 05-15-2011, 08:36 PM   #26
mike06081969's Avatar
With the 5er hooked up, I run around 50-55 psi. That seems to put the truck back to level and it handles and pulls really well. That is also what my dealer recommended. He pulls a Raptor toy hauler with his F250 and he said he runs about 50-60 psi. I don't know what everyone else does, but I hitch up with mine deflated to about 2-3 psi, then inflate them after I hitch the trailer. Before unhitching, I deflate them back to 2-3 psi so the truck doesn't suddenly pop up when I drive out from under the kingpin.
Mike in Tennessee
2011 Blue Ridge 3705BH
2008 Ford F-250 Lariat 6.4 Powerstroke, Auto
Valley 16K slider hitch
Firestone air bags
mike06081969 is offline   Reply With Quote
Old 05-15-2011, 08:41 PM   #27
Grape Escape
Should not need any additional air susp with that trailer and low pin weight. I pull a much heavier 5th wheel and have no need at all
2008 Cardinal 30RKLE 5th wheel XPS tires
2009 Ford F250 CC 4x4 V10 Reese Signature 18K 5th
55 nights 2009
53 nights 2010
44 nights 2011
dezolen is offline   Reply With Quote
Old 05-15-2011, 08:57 PM   #28
Ride Rites, Just put em on last Sunday. Must be the difference in TV. Mine are on a 1st generation Durango
Rockwood 8293RKSS
Old 05-16-2011, 07:26 AM   #29
M109Rrider's Avatar
Honestly I've never checked the pressure with the trailer hooked up. Best ride so far is 30psi before the trailer is hooked up.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 05-16-2011, 02:59 PM   #30
minimum on my firestones is 5 psi
with my 33' toy hauler i am around 10500-11500 lbs loaded up. 45 lbs in my bags yields the best ride/handling (with a half ton pickup). i have my pickup leveled, so the front end sits the same height as the rear when unloaded......and with the 45 lbs in the bags my rear is almost back up to level with the front. if i bump up the pressure to around 55 lbs i am totally level......but i start to sacrifice ride quality and notice a harsh, choppy ride.
2006 Cherokee Wolfpack 295WP / 2012 Dodge 2500 6 banger - 2 Interstate U2200 6v, 1500w inverter, clear lens LED clearance and tails, Kicker 15'' L7 solobaric, Polk component set, Kicker KX850.2 & ZX350.4 amps, Starlight Revolution 300 lumen LEDs EVERYWHERE!
Bocephus is offline   Reply With Quote
» Online Users: 593
123 members and 470 guests
2000XLifted, 4Jeeperz, 5Galvs, Adony, alphadog99, Andy R, Bandit114, Barney1, bean, bear17, biken201, bikendan, bobbygee, boubou, brookside, Browndog, Busman1947, Cafjackracing, Cascade Bob, case1175, cdbus, chiro, chof16, comfun1, cyclepuck, dashonthedash, dasimser, Dave_at_FastwayTrailer, ddavis662, ddemme, dec1952, deerslayer, Dennis Carpenter, Deputyseven, DGrissom, DonG, donn, Dukejr, dummin4fun, elind, forthefunofit, FreedomTracker, frfan, gbpacker, GeorgieGirl, Gizzerd, Gman88, Gollum, Happy Vibe, HWII, iscotty123, isz, itat, JamesR, jasni, Jeep4Two, JJones, JoeR, Joker, jphillips1075, jrcouture, jsutherl, jwuertz, J_KHawthorne, kegoneill, kfroe, kjoh75, LFugate, lowbubba, Mad4sax, McLuer, mesquiteguy, mhartzel, mia, Mr. Legato, mrmurph, MT28rk, mtnguy, NanaKaren, pandkm, pappcam, Pharmofish, PrairieBoy, punkaccountant, pwrplay, Ragin Cajun, Redheaded blue tick, ret2006, rkswyo, rob and lisa, Rogue69, Rsgtivr6, rstewart06, SabreMarv, SabreSam, Sailfish Bret, sbond, shineysideup, SimchaSabre, skippy31405, snowbrid, softwarejoe, southernsky, spike, Steve7575, texashatter, tgarner2000, Tincup13, Titleguy, tking1866, tmmar, torben, Triguy, viper48, VTX Al, wakamicamper, wayne anthony, we2lovecamping, whj77372, Wichitalineman, william.migues, woodchomper, wvfireboss
Most users ever online was 996, Yesterday at 11:04 AM.
Close [X]
