Old 03-17-2014, 09:41 PM   #1
TTNewbees's Avatar
First 5er hitch
Bought my very first 5er hitch. I don't completely understand how it works but it's a pull rite superglide 18k. Hope this was a good decision for my short box but worried about removal in winter...
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 03-17-2014, 09:46 PM   #2
SKnight's Avatar
They're heavy. You can leave it hooked to your trailer, unpin it from the rails, raise the trailer and just drive out from under it leaving it hanging from the pinbox. Then, in the spring, back under it, get it close, let the trailer down just enough to touch, unhook it, move the truck forward and set it up properly then pin it. Out and back into the truck, no strain on your back.
Old 03-17-2014, 09:51 PM   #3
TTNewbees's Avatar
Hmm seems like a good idea, never though of that. Thinking about putting hoist in garage but like Ur idea better but seems like a hanging hitch could create stress cracks on the cap in -50 temps?
Mike
2012 Lacrosse 303RK
Old 03-17-2014, 10:00 PM   #4
TURBS's Avatar
I use an engine hoist to remove and replace mine as needed.
http://www.harborfreight.com/1-ton-c...ane-69512.html
Also use it to lift my 6875 watt gennie in the truck.
TURBS
Sabre owners united!
Old 03-17-2014, 10:03 PM   #5
TTNewbees's Avatar
Sweet, I like that better! Especially the price
Mike
2012 Lacrosse 303RK
Old 03-17-2014, 10:06 PM   #6
SKnight's Avatar
1 Ton Capacity Foldable Shop Crane
TURBS
Wow those things are getting cheap! First ones I saw were $400 or more. That was ~20 years ago. I may need to snag one myself, I've been needing an engine hoist for the longest.
Old 03-17-2014, 10:09 PM   #7
TURBS's Avatar
Or these..
http://www.harborfreight.com/catalog...q=engine+hoist
Or
TURBS
Old 03-17-2014, 10:09 PM   #8
I use a chain hoist mounted on the double rafter that runs across the garage using a webbing strap I also got at Harbor Freight.
I am about $85.00 into this setup.
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 03-17-2014, 10:13 PM   #9
TTNewbees's Avatar
I was worried about chainfall or electric cause my ceiling is drywalled. I like The price of those options tho..
Mike
2012 Lacrosse 303RK
Old 03-17-2014, 10:15 PM   #10
You are going to be punching holes through the drywall to use either. I do like that it is not permanent, as DW parks her car in that bay normally. I drop my hitch onto a 4 wheel furniture dolly and wheel it over to the corner when it is not being used.
ST Williamson
Current
5er, hitch
