Originally Posted by 5picker
Are you sure about this statement?
I didn't think you could use the Revolution feature with any Anderson Ultimate type hitch??
How would you lock the trailer ball to the pin adapter to keep it from turning?
5picker, looks like I had a brain fart with that one. You can only use the Andersen Ultimate hitch with a Reese Revolution/Sidewinder if you have the lockout bolts installed. That's because there's no way to use a wedge like you would with a traditional 5th wheel hitch to prevent the coupler from swinging at the ball. So it effectively eliminates the benefit of the Revolution pinbox.
So you can use either the gooseneck version or the rail mounted version provided you have the lockout bolts in.
I stand corrected. Thanks for catching that.
If you have a short bed (i.e. 6.5' bed, not 5.5' bed) the Andersen moves the ball back a few inches and you can get an extender to move the gooseneck ball in the bed back a few more inches, but you have to be cautious of how far you move the pin back so that you don't end up with the pinbox contacting the bed walls or tailgate. You can install the coupler facing either forward or back for flexibility. Have a look at these interesting videos on the Andersen Ultimate by FRF member hbillsmith.
