01-03-2016, 07:44 PM
#21
Originally Posted by Todouble
The green gas nozzles all over around here. Amaco's was great for this. And lately they've been switching all the green diesel nozzles to yellow.
Around here Yellow is E85. I googled it and your right there are stations using yellow for diesel.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
01-03-2016, 07:48 PM
#22
Originally Posted by MillerTime
It all happens....google it, and you can search on here. A dude put def in his diesel tank and posted it on here a month or two ago.
I agree with DEF in the diesel tank and my post said that but around here the diesel nozzle is larger then the filler for the DEF so would hard to get diesel in the DEF tank. You may get the gas nozzle in the smaller DEF filler but I doubt if it would fit. Now I have Ford and not sure what size the DEF filler on the Ram is.
01-03-2016, 07:53 PM
#23
CWSWine I just read your post and I have seen the gas nozzle with the green cover in Montana.When I asked the man at station he told me that it didn't make any difference.I almost put gas in my diesel.A person has got to be carful.
#24
Oklahoma Proud
Yep, def in the diesel tank or gas in a diesel tank gets real bad. Diesel in the def tank isn't good (more of an issue with big rig guys) but not near as bad.
Most diesel nozels around here are the smaller ones that are the same as gas nozels.
01-03-2016, 07:56 PM
#25
I agree, I have never seen one but googled it and sure enough they are putting yellow on them which around here that's E85 - Black is gas and Green is Diesel.
01-03-2016, 08:18 PM
#26
Try to use "Car" diesel. It's B5-B10. Truck stop diesel can be up to B20. You'll get better mileage with the B10 in the smaller diesels (under 10 liter) IMHO. The big truck 13 liters, etc... don't seem to mind the B20. (I drive both.)
You will hardly use any DEF in everyday driving.... When towing you will use a lot more.
Def is Highly corrosive make sure rinse off any overspill.
Make sure you keep the red plug in the diesel filler when adding def. You can over fill the def before you know it. Def tank is about 6 gals but I could only get about 2 gals in it when the gage read 1/2.
Did you get 2wd or 4wd?
Joy & Mel
2022 XLR Nitro 351
2022 Ram 3500HD MegaCab BigHorn 4x4 6.7L
2020 Indian Roadmaster
01-03-2016, 08:20 PM
#27
I got 4x4. Live in Pennsylvania and feel it is necessary in winter. Thanks all for the info!
Matt
Elizabeth
2013 Roo 19
2013 Ram 1500
01-03-2016, 08:37 PM
#28
I'm on my first one, too... piece of cake... I hope you love it as much as I do.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
01-03-2016, 08:38 PM
#29
Canadian Contingent
The filler tubes are clearly marked between the two. It would be difficult to mix them up. After your first fueling it will become second nature. The diesel knozzle won't fit in the DEF port.
You should always pay attention to what nozzle you're grabbing!
You bought a great truck!
Les and Bonnie with 4 Leggers Bella and Shelby
2011 Cedar Creek Touring Edition 36RE 3 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Anderson Ultimate Hitch
01-03-2016, 08:52 PM
#30
Canadian Contingent
This is my first diesel truck as well. I joined this Forum. I learned a ton.
http://www.turbodieselregister.com
Have a look under 4th Generation Ram Forum.
01-03-2016, 09:04 PM
#31
I have never seen gas nozzle marked diesel with green cover!!! Larger diesel nozzles won't fit in the Ford DEF tank, you make mess trying to put in - you might get the smaller gas nozzles in the smaller DEF tank filler. I guess Ram could be different, never checked. I guess you could take the blue nozzle marked DEF put in your diesel tank.
Don't stop at a BP station. I think it's a foolish disservice to their customers, but I have in fact fueled up at a BP station with green gasoline pump handles.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
01-03-2016, 09:06 PM
#32
You could also look at the label, not just the handle colour.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
01-03-2016, 10:07 PM
#33
Who Dares, Wins
2016 Sabre 36QBOK
Glad I can read... If I was color blind I'd be sol...
Have a Chevy, but my first diesel as well.. Love it, not any harder to take care of for me.. Enjoy your new rig.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
01-03-2016, 11:37 PM
#34
2016 Sabre 36QBOK
this
01-03-2016, 11:43 PM
#35
Canadian Contingent
Originally Posted by jerky
this
01-03-2016, 11:55 PM
#36
Gee I wonder what would happen if put a green handle gas nozzle in your tank and seleted diesel.... Hmmmmm let me think.... Hmmm nothing would come out of the nozzle. That would be a indication that you just many have the wrong nozzle and if push gas you deserve what you get.
01-04-2016, 12:12 AM
#37
Oklahoma Proud
I've accidently done that several years back. All the nozzles were black, i grabbed the wrong one and then hit the diesel button, of course nothing happened, so i grabbed the next one and ( it was the correct nozzle) and everything went as it should.
Case in point.....stuff happens even when you've been doing it a while. It's something to always think about though!
01-04-2016, 07:24 AM
#38
Originally Posted by acadianbob
I'm not being a smartie here but I'd give that owner's manual a complete reading; and the maintenance guide.
Exactly!!!!! Biggest thing I can suggest is to follow the engine/chassis maintenance schedule as stated in the owners manual. Oil changes, filter changes, water removal from the fuel system are a few of the critical items that need to be attended to to keep your diesel in tip/top condition.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
01-04-2016, 09:05 AM
#39
Canadian Contingent
What do you guys think of the new Rams ability to tell you when to change your oil?
I'm at 5000 miles and still at 60% oil life on the EVIC.
I would think the first oil change should be sooner than 8-10,000 miles.
Unless the new trucks are running synthetic.
01-04-2016, 09:17 AM
#40
They are; Cummins ships the engine with Synthetic oil. This was pointed out to us when we toured the factory with the "Turbo Diesel Register.Com" members at Cummins open house for us.
For all new owners of the Ram Cummins diesel engine trucks and the new Eco-Diesel 1500, I would check out Turbo Diesel Register. Com web site. There is a wealth of information on that site and it is geared towards people who want to get the most life out of their trucks. I have been a member since Nov 07, when I purchased a 08 new and this is the best site on the internet for the Ram Cummins equipped truck.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
