01-06-2016, 07:04 PM
#81
Originally Posted by sunnyinfla
Number one it would help you if you add 2 gauges an exhaust gas temperature gauge and a boost gauge...If your going to be towing diesels generate alot of heat and you should keep your egt's below 1200,excessive heat can ruin that motor....if i get into alot of headwinds the temps shoot up and i have to bring it down to a lower gear,good luck with the truck,,,,
The ram comes with a boost gauge, and I see no need for egt gauge on a stock truck.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
01-06-2016, 10:25 PM
#82
Canadian Contingent
Originally Posted by CWSWine
I agree with DEF in the diesel tank and my post said that but around here the diesel nozzle is larger then the filler for the DEF so would hard to get diesel in the DEF tank. You may get the gas nozzle in the smaller DEF filler but I doubt if it would fit. Now I have Ford and not sure what size the DEF filler on the Ram is.
I don't know how you'd mix the two up.
At least, my DEF filler tube has a cap and is a different colour.
Les and Bonnie with 4 Leggers Bella and Shelby
2011 Cedar Creek Touring Edition 36RE 3 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Anderson Ultimate Hitch
01-06-2016, 10:52 PM
#83
I thought the same thing but I guess get guys mess up!!!
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
01-06-2016, 11:14 PM
#84
Oklahoma Proud
Look at this thread on post #137 on for a few pages. (I dont know how to do links off the app). This guy stuck the def nozzle in the non-capped diesel and added some def before he realized his mistake.
01-07-2016, 07:17 AM
#85
FYI....I own a STOCK RAM with a 6.7 diesel and i pull a 10000lb fifth wheel and i've seen egt's exceed 1200 degrees....
Save a beer for me!!! Happy Trails....Be Safe....
01-07-2016, 06:38 PM
#86
Check with other users and you may find that a diesel additive might be beneficial. I use it all the time and with over 175000 miles and no problems it appears to be a good additive for me. Not all diesels need it but with some of the poor quality fuels out there, it might just be a good investment. Also, agree with above mentioned there are many different colored handles for the diesel and gas, so read the words.
01-07-2016, 07:46 PM
#87
After the first oil change is due, replace with high quality synthetic oil, I use the best Amsoil ( AMSOIL - Synthetic Oil, Motor and Engine Oil, Lubricants, Air Filters, Oil Filters and Greases). Change all filters and change air filter to a K&N reusable filter. Money saved on all these.
I've never needed a timer to cool down turbo. I don't hammer down and shut it off. Last few minutes of travel are usually at an idle.
01-07-2016, 07:58 PM
#88
As for the DEF dilemma.
1. PAY ATTENTION
2. Don't fill DEF fluid from a Fuel Station Pump.
3. Replenish your truck DEF fluid from a 1 gallon jug.
4. When 1 gallon jug gets low of DEF fluid fill that at a Fuel Station Pump. Or buy it a a retail store.
5. PAY ATTENTION
PROBLEM SOLVED !!
