Old 07-02-2019, 07:44 AM   #1
First fifth wheel tow
Brought our new RV home Saturday. This weights 11,575 dry so I'm rough guessing about 11,800 or so +/- with full propane tanks and batteries.
I noticed what many had said, very stable, no sway even with a little wind. I did notice slight chucking which I suppose is expected. I purchased a B&W Companion hitch, research shows that to be a pretty decent hitch.
Truck did well. very noticable difference between towing 9.5 / 10K vs this camper, and also more surface area up high catching wind. I was in pretty hilly terrain and was able to pull in 5th at 65 and about 2200 RPMS.. I did upshift to 6th just for giggles and it pulled level fine and very minor hills fine, but I think I'll use 5th 95% of the time to reduce wear on clutch and keep the EGTS down. It seemed happy there.
I have several hundred feet of wooded driveway to back down at home, and wit the traditional pull trailer It was never an issue. With this one it took me 40 minutes to get down and parked. The overall length is only 2 feet more, but the pivot point and having trees against the driveway really kept me from getting lined up good.. I'll cut some trees back to help for future. It's just different and IM sure Ill get used to it quickly. I didnt measure the sag, but it sagged a few inches. I have a payload of about 4200. So some tweaks here and there I think i'm good.
I love having the 8' bed I have all kinds of turning radius.
ID:	208741   Click image for larger version
Ron and Kathy
2019 Cougar 369BHS 5'VR
2018 Cherokee Limited 304 BH (Traded)
Joyfully Towed with a 2018 RAM 3500 6.7 G56
ronheater70 is offline   Reply With Quote
Old 07-02-2019, 07:57 AM   #2
Ejs4029's Avatar
Congrats on the new 5th wheel you have a nice looking setup
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is online now   Reply With Quote
Old 07-02-2019, 10:23 AM   #3
Jim34RL's Avatar
The 5er's do back up very different than the pull behind trailer. The reason is the pivot point is over the rear axle in most case or close to it. The trailer will start to turn very slowly but once it gets going the trailer will move much faster. This takes practice and practice to get the feel of the trailer and backing up. This will come to you in time just hang in there.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 07-02-2019, 11:38 AM   #4
Thank you!
Ron and Kathy
Old 07-02-2019, 11:40 AM   #5
Yes this is exactly what I noticed. Pretty slow to initiate turning but once engaged it turns quickly. I have a gentle curve about 1/2 down my wooded driveway towards where I park it and to get it to trun right I had the truck in the woods against the trees.. I know I need to start turning sooner now.
Ron and Kathy
Old 07-02-2019, 12:39 PM   #6
CaptnJohn's Avatar
Nice outfit and you did great backing. You do have more rear sag than I like, could be the picture.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 07-02-2019, 01:17 PM   #7
I need to measure the sag, I dont think its as bad as it looks, that shadow on the wheel well plays tricks. It felt real good on the road. Im just shy of 4200 payload. I would add bags if absolutely necessary but I think Ill be o.k.
Ron and Kathy
Old 07-02-2019, 01:38 PM   #8
We were shocked at the feel of a Ram diesel towing a fiver compared to a 27í boat trailer.
No stress! The biggest danger is dumb drivers who do not know how to merge on a highway. We do not change lanes quick.
tomkatb is offline   Reply With Quote
Old 07-02-2019, 04:03 PM   #9
DouglasReid's Avatar
One thing to consider regarding the "Sag" or "Squat". By letting the rear end drop so low it will raise the level of you headlights and blind oncoming drivers at night.
IMHO a set of air bags to eliminate that is in order.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 07-02-2019, 04:26 PM   #10
Lins's Avatar
Yes, you definitely do!
2007 Rockwood 2701SS
2014 Triumph Bonneville. NH Togas, TTP Tune 3
1953 GMC 9314
Lins is offline   Reply With Quote
Old 07-02-2019, 04:32 PM   #11
X2- bags will help level, stabilize, and increase your comfort and well.
Lvn2tvl is offline   Reply With Quote
Old 07-02-2019, 05:48 PM   #12
I used timbrens to level the truck and eliminate the sag/headlight aim issue noted above.
The one below is for my truck. Very happy with them and easy install too. For me the most important thing is that they are a passive system.
Timbren DR3500CA Suspension Enhancement System https://www.amazon.com/dp/B001TNBT16..._079gDb6QXKDTR
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 07-02-2019, 06:18 PM   #13
justpassinthru's Avatar
Sag
Look into Timbrens. Google them or YouTube them. Friends told me about them. They really do work. Hope this helps
justpassinthru is offline   Reply With Quote
Old 07-02-2019, 08:21 PM   #14
ronheater70 - welcome to the new world of 5th wheel towing. DW and I finally agreed to upgrade to a 35-foot Cardinal 5th wheel a few years ago. We are fortunate to have just enough space in our driveway to park the trailer behind our front gate, but there is less than 8-inches of clearance on each side between the neighbor's block wall and our brick chimney. It took me many tries before I figured out precisely where to turn to enter our driveway while attempting to back into our spot. I am still learning, but so far no damage to trailer or gates/chimney, or block wall.
Backing in to our driveway is still the most stressful part of any RV trip we make. You are fortunate to have lots of room. Enjoy your new rig!!
Jakie-Boy is offline   Reply With Quote
Old 07-02-2019, 08:42 PM   #15
Now a "Top Member"
EdJunior's Avatar
Welcome and congrats on the new rig. It looks great. I think everyone else has said it all, but I will add, it does seem to be squatting a bit too much. I would go for the air bags, only because I have experience with those. You can adjust them as needed, and with a wireless remote compressor, you can do it on the fly. It will definitely help with the squat, and the bounce.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 07-02-2019, 08:46 PM   #16
It really tows well, I'll measure it when Im hooked next. I'll probably leave it alone for this season as because of big full extended family vacation (non rv related), we will probably only get it out one more time, possibly two and those are close by. It really is a solid feel though.
Ron and Kathy
Old 07-02-2019, 08:47 PM   #17
Thank you! Yea I built a small retaining wall at the back of our concrete pad to extend it just a bit. Glad I'm not as close as you!
Ron and Kathy
Old 07-02-2019, 08:47 PM   #18
robbiels7's Avatar
I stopped riding in the right lane for that very reason. If people don't like me in the middle lane they can pass me.
robbiels7 is offline   Reply With Quote
Old 07-02-2019, 08:49 PM   #19
So far all of our trips are 1-6 hours away..Always leave early in the morning and haven't traveled at night thus far over the last 3 years. However It's certainly something to consider for future trips.
Ron and Kathy
Old 07-02-2019, 09:06 PM   #20
Nice set up, long bed makes all the difference.
Your sag is fine. I wouldn't put airbags - it will make your 5ver ride even more nose-high than it is right now.
Is your BW hitch on its lowest setting?
2020 Coachmen Chaparral 360IBL
2018 Ram 3500 SRW
AndreTheGiant is offline   Reply With Quote
fifth wheel, wheel
