Old 08-13-2015, 04:18 PM   #11
First upgrade I do to a truck is 8 or 10 ply tires. Currently running cooper at3 tires. Awesome. Good traction, strong as hell, and I can air them down a little when not towing. 80psi in the rear and 70 in the front seems to be the ticket for my towing needs.
prestonj12 is offline   Reply With Quote
Old 08-13-2015, 04:28 PM   #12
MtnGuy's Avatar
Originally Posted by billb800si View Post
Unless you have "D" rated trailer tires (or higher) 55 is your maximum speed anyway.
Huh ??
ST tires are rated for 65 mph, regardless of ply rating.
LT tires may help the on the tow vehicle a bit, but other things seem to be at play here.
Old 08-13-2015, 04:36 PM   #13
BombDoc's Avatar
Originally Posted by J.Fallon View Post
Took off down I-77 from Mooresville NC to Hunting Island Sc. 2014 Ford F-150. Reg cab 5.0 with a 6.5 bed. 2015 21FBRS. No wdh. Thought I was going to wreck the first time a semi went by. Go the death wobble and the dash was lite up like a Christmas tree. Go it slowed down. Got off interstate and took US 21 all the way 7 hrs. Any how. Have a good friend down here gonna hook me up with a Reese WDH. Please don't ever to without one!!!! Or at least test run the interstates before hand.
Enjoy Hunting Island. I'm local if you need any advice.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is online now   Reply With Quote
Old 08-13-2015, 04:36 PM   #14
15 -21FBRS 17-F150 2.7 e
J.Fallon's Avatar
WDH
Thanks for the advice. Headed to pick up the WDH now to get us home and just ordered a 2016 F250 lol I won't have this problem with this trailer
J.Fallon is offline   Reply With Quote
Old 08-13-2015, 04:42 PM   #15
mud yapster's Avatar
I bought a used 35' TT and towed it home 60 miles with my F350 SRW and 55 was the limit or it would start to sway side to side. Scared me. LOL took it to my deer lease and left it there. Never did get a WDH for it but we never went very far away from the deer lease with it. had it 10 yrs and sold it for $300 less then what I paid for it. Regret selling it cause I never had one issue with it.
Get you a WDH sway control you will be surprised how well it tows. We have a 5er now and it's a totally different towing experience. Easy. But Turning is different.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-13-2015, 04:57 PM   #16
MtnGuy's Avatar
There is no guarantee that an F250 won't still have problems towing a trailer without proper weight distributing, sway control, and correct trailer loading to make sure there is enough tongue weight. The cause for the current sway problems need to addressed 1st.
The empty weights on that trailer list the hitch as 10.8%. If much of the load is towards the back of the trailer (in the fridge and rear wardrobe), the tongue weight could be reduced to under 10%....a recipe for sway.
The bathroom is in the back !! As you add waste to the tanks, the total weight increases as it takes off weight on the tongue. Traveling with empty waste tanks should be the rule when the tanks are in the back.
Traveling without a WDH with ~500 lb. tongue weight is another big problem. The rear TV axle is probably overloaded, and the front axle doesn't have enough weight on it.
Sway control is very important. Integrated sway control incorporated in the the WDH is the best way to go. Check out Equal-i-zer 4pt, Reese Straight Line Dual Cam, Husky Center Line, or Blue Ox Sway Pro. ProPride or Hensley are top of the line (but not cheap), and are much cheaper than a new truck.
I pull a 28.5' trailer weighing 5500 lbs with an older F150 running P-tire () with nary a problem. There should not a problem with a properly equiped 2014 F150 pulling a 22' trailer that is setup correctly.
Old 08-13-2015, 05:00 PM   #17
Ford Idaho's Avatar
Why not pony up just about one more payments worth and get the 350?
Old 08-13-2015, 05:01 PM   #18
I'm not quite following this. The term "death wobble " usually refers to a severe wobble in the steering wheel indicating a problem with the front end of the truck. And what would lack of a wdh have to do with your dash lighting up? The f150 is more than enough truck for that trailer!
larryo is offline   Reply With Quote
Old 08-13-2015, 05:49 PM   #19
Your right I missed that on original read.
Explain your death wobble and all the dash lights OP.
Old 08-14-2015, 09:13 AM   #20
An F150 is easily able to tow that trailer so there's no need for a 3/4 or 1 ton truck. A properly set up WDH and properly loaded trailer would have given you years of great towing.
Anyway, Ford thanks you for your purchase.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
