Old 08-14-2015, 09:38 AM   #21
His F150 has automatic sway control built into its trail erring package. When the truck sensed the sway, it automatically applied the trailer brakes and lights up
the dash panel with bright warnings. It sounds like the culprit here is too little weight on the tongues. I use my F150 to haul cargo trailers, even heavier than his. No WDH and no problems at highway speed (except for the time I learned about the automatic sway control when I fell asleep).
2016 Berkshire XLT 43a
TwiceTheIce is offline   Reply With Quote
Old 08-14-2015, 09:44 AM   #22
mud yapster's Avatar
Thanks for the info on the sway control lights.
Stay awake man camping season is upon us
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-14-2015, 10:00 AM   #23
Markwie's Avatar
It also works faster than the driver ever could. I've had some serious side winds in the columbia river gorge and the truck's active sway control came on and kept everything straight.
For the OP.
I tow a much larger and heavier trailer ( FR 268rks ) and after putting on airbags, rear sway bar, and LT tires the difference in towing is night and day. I of course always use a WDH and sway control. The cost of the tires, bags, and sway bar will be FAR less than the hit on buying a new truck. I figure at right around $1500 for the whole shebang. I am also running a 2014 F150.
2015 Vibe 268RKS
2014 F150 Supercrew 4x4 3.5L EB 3:31 axle
1999 F350 Supercab V10 4x4 3.73 LS
Markwie is offline   Reply With Quote
Old 08-14-2015, 10:18 AM   #24
Pixelbum1's Avatar
Had a 25' Land Yacht for years hooked to a Suburban ("the" tow vehicle of choice-period) and only used a weight distributing hitch(WDH) with it. No sway control needed due to the perfect combo of TV and towability of the Airstream(dual axles and slipstreaming!).
Never, ever, had any problems with sway going through the Smokies...or...the W. Va.
turnpike many a time. Would get "pushed" a little from dirty air produced by the faster
semi's but not pucker inducing. MY question to you...do you have dual axle's or the
single variety?? I started out with a small 15' single axle and vowed NEVER to do that
again...was like pulling\backing a juvenile squirrel most of the time...bad bad bad.
Pixelbum1 is offline   Reply With Quote
Old 08-14-2015, 12:36 PM   #25
Sway and wdh
Just completed a 5,000 mile (plus) trip towing a 26 ft Wildwood, using a 2006 Ram 2500. I use a Weight distributing hitch, with 1,000 pound trunion bars, and a antisway bar. I drive at 65 most of the time, except when I have to make time, or the fuel is less in that state, when I bump it up to 70. Passed by many trucks, and we rode solid like we were on a rail. Never a twitch or sway.
The force of air being pushed by the front of the big rigs is more noticeable when we were towing a 33 foot trailer, but even them I just tightened the sway bar some more, and rode steady.
When I was a paramedic, in the mountains of California, I saw way too many RV's on their side from sway problems after being passed by trucks. NEVEr drive without antisway and WDH. Ever.
hankpac is offline   Reply With Quote
Old 08-14-2015, 12:44 PM   #26
I pull a Salem Hemisphere 282RK with an F150. I have the Equalizer hitch and love it. Not only does it distribute weight, but contols sway. I had to make an emergency stop on I70 last week at 60mph due to an accident up ahead. Stopped with no problem and trailer stayed in line. I meet semis without issue.
I highly recommend the equalizer. Best $550 I've ever spent.
Originally Posted by txredfish View Post
You are right. You do need a WDH. Reese is OK. I used a Reese dual cam for several years before going to a motorhome about 10 years ago. I was also pulling with a 1998 F150. Trailer weighed about 7000 lbs. Trucks going by still bothered me. Now, I have went back to a TT a couple of months ago and pull with 2014 F150 and 5.0. I purchased a Equalizer WDH, but I have not been on an interstate and passing trucks so I cannot vouch for it yet. But I would never pull a TT without a WDH.
Lowes48fan1 is offline   Reply With Quote
Old 08-14-2015, 01:39 PM   #27
BiigDaddy's Avatar
Originally Posted by MtnGuy View Post
Huh ??
ST tires are rated for 65 mph, regardless of ply rating.
LT tires may help the on the tow vehicle a bit, but other things seem to be at play here.
Not to hijack the thread, but these are my Carlisle ST LRD tires and the speed rating is 87mph. Not that you'd want to do that....just some info for everyone.
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
Old 08-14-2015, 01:52 PM   #28
MtnGuy's Avatar
I had heard that some ST tires were rated for more than 65 mph......good to know.
Old 08-14-2015, 02:46 PM   #29
Phat Phrog Stunt Crew
elind's Avatar
I remember my first pull with my Mountaineer and 26' TT and it was ugly. The TT came with WDH and no instructions because it was used. In the first mile I hit a bump and SUV was all over the road. When I pulled up the equalizer bars and it put weight on the front wheels all was well.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 08-14-2015, 03:11 PM   #30
I must be blind I did not see the speed rating
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
