Those bars will pivot to the side, Get out from under the trailer and move them out, then back up under the trailer tongue and hitch to the ball, once that is done use the tongue jack to raise the trailer AND tow vehicle until you are able to swing the bars over the pins and onto the L bracket using the tool furnished with the hitch. Secure the bars to the L bracket and retract the tongue jack. Attach the safety chains and plug in your electrical connection. Do a walk around inspection and you should be ready to go.
Bill Mullins
2016 XLR Thunderbolt 385AMP
2012 Ford F350 DW 6.7 Power Stroke
