Old 06-28-2015, 05:40 PM   #41
Once you go dies for a TV, you never go back!!!
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 06-28-2015, 06:24 PM   #42
First Trip Towing with a F 250 Power Stroke Diesel
Originally Posted by B and B View Post
Titamium X. The turning radius on my new F250 is tighter than the F 150. Maybe in later years they changed this.
One question, amyone running the camper package on there F 250? Adds extra leafs in the front and extra in the rear with a overload spring as well. The rear has a stabilizer bar as well.Wondering how it handles with a heavy 5er.
I have a 2011 F-250 with the camper package and have a flagstaff 5ver. It drops the back end so the overloads are just barely touching the rubber pads. I recently installed airbags because it looked like it was really squatting but was only down about a 1 1/2" due to the truck riding level. I run the airbags with 30psi unloaded, then hook up the fver and the truck sits level now.
Ramrod79 is offline   Reply With Quote
Old 06-29-2015, 03:16 AM   #43
Witch Doctor's Avatar
The turning radius is just terrible on an F250 I agree. I just took mine in for service and had a $500.00 bill when done or so. I asked the mech. what is the difference between mine an a SW 350. He said if I added a rear leaf spring and changed my front end springs, Nothing. How true that is I do not know,
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-29-2015, 07:20 AM   #44
Got autocorrected.... dies is suppose to be diesel. LOL
Doc
Old 06-29-2015, 09:32 AM   #45
AMG
F2350 srw has a 1" larger rear block and a different door sticker than the F250 srw. That's it.
Camper package diff story.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 06-29-2015, 09:38 AM   #46
B and B's Avatar
AMG, that's what I saw as well. I am going to get axle codes off the F 350's at the dealership and compare, The springs are actually heavier on my 250 than the 350 I looked at. I can see them putting a lighter axle on a F 250 as the same engines and transmissions are in both trucks with the same torque capability.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 06-29-2015, 09:42 AM   #47
AMG
There's posts on powerstroke forum and ford-trucks forums where people compared exact Ford part numbers and say they are 100% identical other than the block , sticker, and logo outside. Axles same. Leaves same, brakes same, etc etc. Search search on powerstroke.org you'll see the threads
Old 06-29-2015, 09:57 AM   #48
100% correct!
The camper package is just a stiffer sway bar in the rear.
Doc
Old 06-29-2015, 10:03 AM   #49
The difference on the 2013+Chevy/GMC 2500 to 3500 SRW is just the rear spring packs. One extra leaf on the 3500. That's why I did a 2500 and added the Firestone air bags. Ride of a 2500 and capacity of a 3500 SRW, with exception to the sticker on my door.
Doc
Old 06-29-2015, 11:12 AM   #50
AMG
I'll also add to the F-250 vs F-350 SRW discussion, that you can order an F-350 with the 10,000 GVWR sticker. At that point, the only difference between the F-250 and F-350 SRW is the 1" block and the emblem on the sides. Otherwise, they are the same truck. Why would someone do this? Well, good question (which basically is the reason for the F-250 and F-350 difference) is that in many states, a vehicle with over 10,000lbs GVWR requires a commercial registration from the DMV, and can at times cost more to insure.
I dont even own an F-250 but I just know all this from my searching. I am currently trying to figure out how to get rid of my 2015 F-150 for an older F-250 diesel :P
diesel, power stroke 6.8, towing
