Old 05-22-2016, 05:09 PM   #21
Crusadernoob's Avatar
You must bring your truck and trailer to a scale and get accurate no's on it. Front axle/rear axle full of fuel. Next, front axle/rear axle, trailer axles, no WD hooked up. Then again WITH WD hooked up. The dangerous situation you speak of makes me think not enough weight on the tongue, you need to KNOW what you've got.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!
Nights camped in 2014 37
Nights camped in 2015 40
Nights camped in 2016 39
nights camped in 2017 7
Crusadernoob is online now   Reply With Quote
Old 05-22-2016, 05:38 PM   #22
Our fresh water tank is in the rear, so that wouldn't help. Trailer is level when hitched and we're not sure of the weight rating on the WDH.
Sierracamper is offline   Reply With Quote
Old 05-22-2016, 05:43 PM   #23
Thank you Crusadernoob, we will be taking it to a scale here locally. Currently, our trailer is in for service for a water leak. We've only been able to take it out for the shakedown once and had all of the towing problems. Our last trailer was heavier than this one and never had sway issues with the WDH.
Old 05-22-2016, 05:56 PM   #24
You can weight the tongue without going to a scales. https://www.google.com/?gws_rd=ssl#q...bathroom+scale
Old 05-22-2016, 06:12 PM   #25
Thank you oldcoot.
Old 05-22-2016, 06:33 PM   #26
dieselbobcat's Avatar
Quick, easy and useful ballast up front is a pair of 6V trojans in place of the stock RV battery
2014 Rockwood Ultralight 8312SS Diamond Edition
2011 F150 Super Crew 4x4 5.0L - Traded!
2016 F350 Lariat Ultimate Super Duty Crew Cab 4X4
Northern NJ - God Bless America!
dieselbobcat is online now   Reply With Quote
Old 05-22-2016, 06:57 PM   #27
Stormrider151's Avatar
In looking at your floor plan you should be heavy at the tongue. That super slide is a significant amount of weight plus the front kitchen with all of the appliances. Unless you are carrying very heavy gear in the rear storage compartment you may find you maybe over weight at the tongue. As others say you really need to weigh your rig. Which is a very nice trailer BTW.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-22-2016, 06:58 PM   #28
asquared's Avatar
Originally Posted by OldCoot View Post
Dual sway controls but why the wdh? To what benefit? If his hitch has the capacity, he sure isn't in need of transferring weight to the front of the truck or off the rear or even back to the trailer.
The class V hitch on fords state over 500 lbs tongue weight requires a wdh. His trailer has over 500 lbs tongue weight.
As stated above, you need to weigh your set up. Ideal tongue weight is 13-15% of loaded trailer weight. When you check your wdh set up, you want your front axle to weigh as close to unloaded weight as possible without going heavier.
Now lets talk about what you are feeling. True sway is side to side oscillations increasing in speed and size. Is that what you are getting? Are you getting some tail wiggle? Or are you getting front to rear porpoising? Each of these conditions are fixed a little differently but in the end it all boils down to weights, wdh set up and proper tire inflation. What are you running your truck and trailer tires at? Trailer tires should be inflated to max cold psi. Truck LT E tires are usually pretty good around 65-70 in front and 75 in rear depending on what your tires are rated for.
Does your wdh have integrated sway control? if not I would switch to equal-i-zer 4 point hitch or reese dual cam. Either will suit you fine. equal-i-zer is easier to adjust than the reese.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is online now   Reply With Quote
Old 05-22-2016, 07:01 PM   #29
indybp57's Avatar
I would verify the tongue weight is correct before proceeding down any rabbit trails. #1 cause of sway above a certain speed is being tail heavy.
2013 Roo 183
2012: 1042 Miles, 13 Nights camped
2013: 2772 Miles, 27 Nights camped
2014: 2259 Miles, 30 Nights camped
2015: 1644 Miles, 20 Nights camped
2016: 550 Miles, 11 Nights camped
indybp57 is offline   Reply With Quote
Old 05-22-2016, 07:34 PM   #30
Stormrider151 no heavy gear in the rear, other than hoses, a couple of chairs, bins with some supplies,etc. the king bed slide is pretty heavy. Fish tailing when we picked up empty.
sway
