Old 03-24-2016, 09:15 AM   #11
BamaBob's Avatar
Originally Posted by wana65stang View Post
Hey Grumpy, not asking for a general procedure , asking for what you pull and what you have to do to it, trying to get a feel for what is the easiest vehicle to use as a toad. Cheers
Researching this as well and according to what I have read, Jeeps are by far the easiest and least complicated vehicles to tow: no speed or distance restrictions, nothing to disconnect before towing - just hook up, put the transfer case in neutral and go.
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 03-24-2016, 11:43 AM   #12
Carmel's Avatar
Jeep Wrangler. Take the key out, transfer case in neutral, hook up lights and brakes and go as far as you like.
Carmel is offline   Reply With Quote
Old 03-25-2016, 08:14 AM   #13
Hey Carmel , just to clarify are you talking about a automatic transmission or stick?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-25-2016, 06:33 PM   #14
Carmel's Avatar
Mines a stick and I put it in 2nd. An automatic you leave in park I believe, neutral is taken care of at the transfer case.
Old 03-30-2016, 02:28 PM   #15
Rockin M's Avatar
I just ran a charge line from my 2014 Forester to a 2013 Chevy Equinox. I put a 20 amp fuse at the Chevy battery but I have heard that a diode might be necessary. Can anyone comment on the diode and how do you calculated the value of the diode that might need to be added.
Thank you
Barry & Donna
2014 Forester 3011DS
2013 Chevy Equinox
Rockin M is offline   Reply With Quote
Old 03-30-2016, 02:42 PM   #16
2012 Ford Focus. stick shift, put in neutral , just hook , plug in and go. no distance restrictions ,no key in ignition as the steering wheel does not lock. I can hook and unhook in about 3 minutes,
I also tow a jeep Wrangler, same this basically put trans in gear (stick)
or automatic in park. transfer case in neutral hook up and go.No keys in jeep as steering wheel does not lock,
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 03-30-2016, 02:58 PM   #17
Citrus County, Fl.
GL1800Rider's Avatar
I tow a 2015 Corolla because I wanted something that got good mileage and was reliable. Only requirement is to run the engine 3 minutes before driving. Ignition on Accessories and manual transmission in neutral. No other restrictions. Power shuts off after 30 minutes so I have a jumper from the battery for the Brake Buddy
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 03-30-2016, 03:10 PM   #18
RETIRED
n-e-d's Avatar
2015 Jeep cherokee automatic-DW didnt want a "Jeep" or standard-Blue Ox tow bars hooked to Jeep,Patriot brake system- just clip on brake pedal plug into spare socket, push a button to get transfer case to neutral(only on Active II transmission) put in park shut off engine, no key in the ignition. I use tow bar lights plugged into coach socket and off we go.
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Cargo Van HR DRW EXT DIY Daytripper "My Little Red Corvette"
n-e-d is offline   Reply With Quote
Old 11-09-2016, 08:28 AM   #19
I have a question. I have a Jeep Wrangler and a 2014 Forest River MH. I bought a collapsible tow bar. It has two bolts on each arm up near the hitch and one bolt at the point it connects to the Jeep. Are the bolts supposed to be tight, no movement in them or lightly loose?
2014 Georgetown
2005 Goldwing
2014 Jeep Wrangler
retired Army combat vet
Greydragon is offline   Reply With Quote
Old 11-16-2016, 03:33 PM   #20
BamaBob's Avatar
What model is your tow bar?
Also, most tow bars require you to install a base plate to the TOAD; then there are specialized tow points that the tow bar attaches to.
Can probably help you more once we find out what tow bar system you have
