Old 01-11-2016, 07:17 AM   #101
The Big Toe's Avatar
Originally Posted by WolfWhistle View Post
Actually HP is a measurement of work. If I can lift an 80# bag of cement into a truck bed, that is like torque... my strength. How many bags I can load in a given amount of time into the truck is like HP... or work. Another analogy: we don't get paid for how strong we are (torque); we get paid for the work we do; using the strength to perform what we can accomplish using that strength (HP).
WW
If I can get you to lift those bags instead of me, that's called.......
The Big Toe is offline   Reply With Quote
Old 01-11-2016, 07:59 AM   #102
15,100 lb trailer, a full load of people in the cab
Max Tow pushed to the MAX - Ford Truck Enthusiasts Forums
https://youtu.be/m4tzIOD3ydY
Old 01-11-2016, 10:31 AM   #103
WolfWhistle's Avatar
He was gripping the wheel so hard his fingers turned blue! Was the front tires trying to fly?
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 01-11-2016, 10:41 AM   #104
Originally Posted by The Big Toe View Post
Whats the point of that? If I could talk CSX into letting me, I could get a 100 ton coal car moving with a 79 Pinto, but what would it prove?
Mr Havercamp is offline   Reply With Quote
Old 01-11-2016, 12:34 PM   #105
I think that's the cameraman moving more than it is the front end.
To the other Poster... I guess there is no point other than, maybe, instead of spending all your time thinking of ways and reasons not to do something, going out and doing it.
Or maybe some people is just nutz
Published on Jun 25, 2013
2013 F150 towing a 15,000 lb trailer up a hill! See more here: http://www.ford-trucks.com/forums/12...o-the-max.html
The distortion is caused by the YouTube stabilization program that made it look like the truck was all over
the floating and bobbing is distortion caused by the YouTube stabilization program. The unaltered video can be found here: 2013 F150 EB Hill Pull
And no, the truck is NOT overheating. The Ford Transmission is built to run at 200 degrees nominal, unloaded, every day operating temperature and can take temps of up to 240 degrees with no adverse effects. Which is why you should NEVER use ANYTHING but FoMoCo Tranny fluid and NEVER let a Shade Tree Mechanic mess with it.
It's a whole different ball game from other transmissions. And vehicles.
Old 01-11-2016, 01:40 PM   #106
That's a fine line between being nutz or being an idiot. That guy crossed it. For an encore he should dump some valve grinding compound into the oil and fill the radiator with latex paint and try it again.
Somewhere on the www is a Honda Ridgeline forum. They have an entire dedicated section devoted to idiots that go around towing loads and hauling things grossly above what a Ridgeline is rated for. Its all for bragging rights.....A lot of idiots there.
I don't know. I guess if you never sat around thinking of ways to purposely abuse $50K+ vehicles, that's spending your time thinking of not doing something.
Old 01-11-2016, 03:31 PM   #107
Maybe the point is to show that if it can pull over 15,100 lbs 'safely', that it can handle 10,000 lbs with ease.
And that pull was up a minimum 12% grade. Read the posts.
THAT is impressive
YMMV
Old 01-11-2016, 05:25 PM   #108
davel1971's Avatar
THAT is impressive
YMMV
just because it does it one time, doesn't mean it's a good idea, and it won't survive a 1/4 to 1/2 of a million miles doing that like a diesel easily could.
David & Lynn
Old 01-11-2016, 05:34 PM   #109
Homebrew's Avatar
THAT is impressive
YMMV
Did you hear the tranny banging ?
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 01-11-2016, 08:01 PM   #110
THAT is impressive
YMMV
I guess it proves that it was done "safely" if you say it was.
It doesnt impress me at all. What would impress me is to see him come down the 12% grade at 45 mph and make an emergency stop.
ford
