Old 01-01-2016, 02:51 PM   #31
Kenny kustom's Avatar
Originally Posted by bluewoo View Post
Why Ferrari engineers don't like turbos
I like the idea Ford has But I dont think 100,000 miles is possible with out added cost.
Have you seen the split turbo that Mercedes is using in F1?
The impeller is on the back, and the compressor is on the front.
The charge doesn't get as hot, because the exhaust isn't right beside it.
Interesting design.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-01-2016, 03:25 PM   #32
mud yapster's Avatar
Well either way my 2015 Ram 3500 4x4 long bed Crew Cab dually with the 6.7L turbo diesel with the Aisin tranny with 3.73 axle beats the crap out of my 2001 F350 7.3L diesel 4x4 long bed hands down towing my 18,000 lb. 5er. Hills or not the Ram doesn't slow down for any hill I've been up yet. And the engine exhaust brake is awesome when you let off the gas to stop the big rig. The factory brake controller works flawlessly also. Only have 6000 miles on it so far so time will tell about its dependability, but we love it so far and the big hill we go up doesn't have us at 25mph when we finally get up it. I set the cruise on 65 mph and it stays there.
Good luck with which ever truck you go with and check the tow set closely to make sure you have at least a 20% safety margin with the weigh your going to tow.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 01-01-2016, 03:30 PM   #33
acadianbob's Avatar
Originally Posted by drittal View Post
Cummins comes in last in towing tests because the test are basically races and the cummins is down on Horsepower compared to the other 2 despite having the torque crown.
I agree that the "wide open" tests are misleading. First of all, who tows wide open? Secondly, it rewards horsepower, not torque.
I've often thought that the trailer towing tests would be better served by limiting RPM to something like 2,500 RPM. Lets see what the results are then. The torquey engines would come to the front.
This type of test would make the Ecoboost engines look even better as compared to the gas V8's. It would be in its torque peak whereas the V8's would be almost 2,000 RPM below their torque peak.
It would also be interesting to see the results for the 1 ton diesels. But maybe at 2,000 RPM. That might bring the Dodge to the front of the pack.
Anyway, not picking on anyone's truck. I just think that a different type of towing test could be very revealing.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 01-01-2016, 04:33 PM   #34
Interesting design.
2016 Sabre 36QBOK
Yea thats cool - no pun - I see they put the generator to recover the batter cell between the impellers.!!
2006 Honda Goldwing
2012 Toyota Tundra DC
2015 Cherokee Grey wolf 19RR Limited
bluewoo is offline   Reply With Quote
Old 01-01-2016, 04:42 PM   #35
That's different than the one I saw.
But, interesting.
Here's the other one. Shaft runs through the whole motor.
Name:   ImageUploadedByForest River Forums1451688117.509451.jpg
2016 Sabre 36QBOK
Old 01-01-2016, 06:14 PM   #36
But, interesting.
Attachment 97135
2016 Sabre 36QBOK
Im sure this will be adopted in the near future.
I was reading an old web forum about the towing capy of a turbo charged 4cyl vs non -turbo v6 caravan. The v6 had a higher capacity vs the turbo dispite the turbo had more hp - EGT back then was the problem and long term under load prob destroyed everything.
2006 Honda Goldwing
Old 01-01-2016, 06:41 PM   #37
onetonford's Avatar
Yea 900 ft lbs compared to 430 apples to peanuts. I guess it would.
onetonford is offline   Reply With Quote
Old 01-01-2016, 07:01 PM   #38
CaptnJohn's Avatar
Whatever ~~ Had a 2015 F150 2.7 that I towed 7000# with. Yes coastal NC AND the NC mountains too. Rarely did it see 6th gear with the TT behind it but stayed in 5th except for the mountains. Never lost speed, just dropped to a lower gear. 22 - 23 MPG solo but only 9.3 - 9.7 towing. She will not tow my new 5er for sure but my 2016 F250 6.7 diesel does a fine job with that.
Old 01-01-2016, 08:10 PM   #39
You do realize you are comparing 2 trucks that are 14 years apart, right????? You'd be just as impressed with a DMax or a new PSD.
Old 01-01-2016, 08:41 PM   #40
Oklahoma Proud
MillerTime's Avatar
Yep. I remember the first time i drove a 2nd gen dmax and a 6.0 pwrstroke, i though they were like a race car compared to my 7.3 pwrstroke. They would boogie in comparison!!!
ford
