Old 03-20-2013, 11:53 AM   #1
Ford 6.0 Diesel - how often to clean or replace EGR valve
TV is a 03 Ford F350 6.0. Have heard of problems with this engine. Any info/help greatly appreciated!! Should you clean or replace egr valve or should you spend the bucks and install delete kit??
Cardinal camper is offline   Reply With Quote
Old 03-20-2013, 12:06 PM   #2
You'd be better served going to a Ford diesel forum to ask these questions. Try one of these:
Ford Powerstroke Diesel Forum
PowerStrokeArmy - Powered by vBulletin
http://www.thedieselstop.com/forums/
Len & Cheri is offline   Reply With Quote
Old 03-20-2013, 12:17 PM   #3
Ok. Tks!!!
Old 03-20-2013, 12:24 PM   #4
rotorhead1250's Avatar
How often to clean EGR valve? - Ford Truck Enthusiasts Forums
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 03-20-2013, 12:31 PM   #5
Good thread there!
Old 03-20-2013, 12:40 PM   #6
Dallas Texas
TexasBBQ's Avatar
If you plan on keeping the truck delete the EGR cooler. If it fails it could lead to major engine damage. Even the minor damage would run you $5-7k. And of course, if you're on the road and it fails it just makes everything worst and more expensive. Also install a coolant filter, replace the coolant as recommended or switch to an ELC, install the blue spring mod to save your injectors. There are a few other things to do to ensure a super reliable 6.0. The EGR cooler would be the first.
Last week I got yet another notification of a class action lawsuit against Ford for the EGR cooler, oil cooler, turbo and a few other items that plague the 6.0.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 03-20-2013, 01:29 PM   #7
jevanb's Avatar
not all 6.0`s are bad My friend has 400k of pulling trailers around since 05 all factory, pure stock. never once been to the dealer for repair. but another has been their 4 times for cyl head replacement (studded, and egr removed, light tuning)
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 03-20-2013, 08:21 PM   #8
I had a 06 6.0 was a good truck was a great truck once I deleted the egr stuff and put a good custom tune on it. I never had a problem with the truck. And get a coolant filter for it they are notorious for having casting sand still in the block and it plugs up the oil cooler.
Smitty3215 is offline   Reply With Quote
Old 03-20-2013, 09:12 PM   #9
textman's Avatar
Yep check out this site Ford Powerstroke Diesel Forum
EGR delete and a good monitor to make sure things keep in check...
Oil change and coolant change on a regular basis... Love my 6.0...
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 03-21-2013, 04:00 AM   #10
golfmedik's Avatar
If yo live in an area where you can do it without emissions testing, I would delete the EGR system. The kits aren't that expensive, but then you have to add a programmer. Since yours is no longer under any kind of warranty, that shouldn't be an issue(of possibly voiding it). There are programmers out there that will just turn off the 'CHECK ENGINE LIGHT' when the delete is done. However, do not add any horsepower with a tuner unless you put head studs in the truck or you will blow the head gaskets. Then you are looking at a 'cab off repair' Around here, diesel shops are charging around $2600 for the head stud job. Much cheaper than a dealer. If you go ahead with a delete, coolant filter and putting in head studs(I recommend ARP), then you will have pretty much 'bulletproofed' the 6.0 and it will have a much longer and healthier life.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
