06-10-2014, 05:07 PM
Ford 6.1 gas
Just interested if anyone is towing using this setup in a F250 or F350. I not trying to start a debate on gas vs diesel, however its showing some pretty strong numbers, of course the local Ford dealers all say its great. ( That's what I would expect the to say ). Looking for some REAL user information. Thanks Chuck in Va
06-10-2014, 05:21 PM
6.2?
TURBS
"Sabre owners united"
06-10-2014, 05:38 PM
It might be a 6.2 I thought it was 6.1 in the gas model. I could have my numbers mixed up. I know its the larger engine in the newer f250's. Bigger than the 5.4...I liked it much better when everything was listed as cubic inches..350,327, 454,396,460,302,427 and so on, I understood those numbers. Chuck in Va
06-10-2014, 05:42 PM
not really any "bad" gas engines out there in full size trucks. All of them can go a mess of miles with care. Don't worry Charles, we have only been calling engines by "liters" for 30 years, you will get the hang of it eventually
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
06-10-2014, 05:44 PM
Camper Less Camping
Ford has the gas 6.2L...rated at 434 ftlbs torque at an rpm around 4K or so...
2013 Sabre 32RCTS-6 (sold)
06-10-2014, 05:46 PM
only downside to towing with gas is fuel economy. You will get 50% better in same vehicle with a diesel, and now diesel is only 4 cents more per gallon than gas. Diesel isn't for everyone, but if you will be towing enough, you can justify the extra cost.
06-10-2014, 06:26 PM
You also need to factor in the additional $$$$$$thousands more in the cost of that diesel motor option too !!!
06-10-2014, 06:35 PM
at 50,000 towing miles, the difference in fuel economy has already saved you those thousands back. Not to mention, you will get many thousands more in resale value in the future. That's why I originally said, isn't for everyone and if you can justify the cost.
06-10-2014, 06:36 PM
In Canada, your talking an extra 9000$ for the diesel option.
You can buy a lot of gas with that money.
I have a 2014 F250 FX4 Lariat with 6.2 gas engine.
Very happy with it, plenty of power...of course, I've never owned a diesel, so can't compare.
Black
On a new Ford f250 or F350 the diesel is about a $7000 option. I was just wondering if the gas would compare close to the diesel pulling power. There is no doubt that the diesel will out preform the gas, however for those of us that tow less than others and will also be using the tv as a daily driver could it be a little more cost effective. I was just interested if anyone is towing with one and if they are please with its capabilities.
06-10-2014, 06:39 PM
I agree 100% - we have had both - our 1998 chevy diesel is still going at 175k miles and we had a 1995 ford diesel with over 250k miles and its still going too - but went with gas on latest 2012 chevy HD since we do not tow as much any longer - diesels are BEASTS !!
06-10-2014, 06:40 PM
Diesel is preferred for towing but it is all personal preference of course!!!
06-10-2014, 06:42 PM
after years of towing with various gas vehicles, I finally convinced myself to go diesel last year. I "thought" my gas vehicles were capable enough until I towed with diesel. Almost effortless. I was getting 7MPG towing 7000lbs with a 3/4 ton gas truck. Now getting 12MPG towing 11000lbs with diesel. All the newer diesels have an exhaust brake too. Stops like trailer isn't even there. Consider the resale value of gas vs diesel too. Would you buy a 200,000 mile gas truck? Nobody bats an eye at 200,000 on diesel. Not that gas isn't capable, just that if you convince yourself to go diesel, you won't regret it.
06-10-2014, 06:55 PM
I tow with a 8.1L Chevy with the allison trany. Plenty of towing power. When towing my mpg is 8 and when not it is 11. My buddy who tows with a Ford 450 gets about 9-10mpg. To me not a huge difference especially when I use the truck primarily for towing. In 4yrs I have only put 15k miles on the truck. When I get ready to "part time" I will go to diesel. The typical difference between gas and diesel is 20-30 cents per gallon.
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
06-10-2014, 06:58 PM
when not towing, my 1 ton diesel gets 18MPG no problem. Best my gasser got not towing was 13MPG. Around here, diesel is now only 5 cents more than gas
06-10-2014, 07:09 PM
Racin
I have a friend who just bought the f250 with the 6.2 auto trans his tt is around 10000 lbs I think and he said it pulls very well
2014 coachmen clipper 15RB
2000 ford f-150 super cab 4.2 6 cyl
06-10-2014, 07:34 PM
Camper Less Camping
If you get to test drive both engines...I believe the torque will set the two apart tremendously...gas at 434 ft/lbs torque for gas model vs 800 ft/lbs torque for diesel...again a lot of variables to consider for your particular towing needs on which engine will make you happy
06-10-2014, 07:58 PM
I have the 6.2 in my F250 and like it. I've towed my Surveyor 5er (8750 lbs Dry Weight) for over 5000 miles with no problems. This includes a long haul from Michigan to Florida and back again. It handles the hills good, but does gear down accordingly. I've been getting anywhere from 9.5 to 10.5 MPG. I also added air bags which has made for a smoother ride.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
06-10-2014, 08:02 PM
William
These conversations come up often here and I always respond with the same. I went from a diesel of 10 years to the Ford F250 6.2L. The reason was the initial cost and I only tow about once a month, mostly local, so the torque I lost with the gas is not a big deal. As far as the 6.2L, it pulls comparatively to my old F250 7.3L diesel although not comparable to "modern" diesels. My brother has the Fort 6.7L diesel with the same size camper as me. He only get 12mpg to my 9mpg pulling, and 18mpg to my 14mpg empty. Cost of fuel at these mpg's pulling is a wash.
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
06-11-2014, 12:12 PM
Camper Less Camping
But I also like to think I'm helping the environment
