Old 06-26-2019, 07:35 PM   #1
Lt Jim's Avatar
Ford Air Conditioner problem
We have a 2011 Ford F350 with a 6.7 turbo diesel. We are having a problem with the air conditioner. It will start out great, then the air flow seems to become restricted. We can hear the fan still operating, but little cold air comes out of the vents. If we turn it off for about 5-10 minutes, my DW can feel a few drops of cold water on her feet, and occasionally a few very small chips of ice blow out of the vent. when we turn the A/C back on, it cools great for anywhere from 10 minutes to an hour, then the cycle repeats. Can anyone suggest what's wrong, or a solution for how to fix this? Thanks
Jim & Annie Fahrman
2014 Landmark Key Largo
2011 F350 Turbo
DRW
Lt Jim is offline   Reply With Quote
Old 06-26-2019, 07:57 PM   #2
Failure is my business
2Evil4U's Avatar
Sounds like it's icing up. Have the refrigerant level checked to start..
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 278,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 78
2Evil4U is online now   Reply With Quote
Old 06-26-2019, 08:13 PM   #3
Chuck_S's Avatar
Somehow I suspect the Ford F350 Forum will have more experts than a Forest River campers forum. Just a guess.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 06-27-2019, 08:03 AM   #4
Lt Jim's Avatar
Thanks, I'll check them out
Jim & Annie Fahrman
2011 F350 Turbo
DRW
Old 06-27-2019, 09:35 AM   #5
Grammar Pedant
67L48's Avatar
-- Chuck
Yep, my thoughts exactly. If someone over there had an RV question, I'd send them here. Here is the SD forum specific to your year of truck.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 06-27-2019, 10:23 AM   #6
Sounds like the charge is low and it’s freezing up the evaporator go have it charged or buy the do it yourself kit and you will be good to go.
ChrisRR is offline   Reply With Quote
Old 06-27-2019, 12:44 PM   #7
Too old to be too smart
SpringerPop's Avatar
We discussed this over on Ford Trucks Enthusiasts, and your symptoms sound a lot like what's addressed HERE:
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 06-27-2019, 01:39 PM   #8
My money is on the evaporator temperature sensor.
brannon is offline   Reply With Quote
Old 06-27-2019, 01:45 PM   #9
KyDan's Avatar
It's icing up and could be low on freon or a bad sensor as suggested.
My vote is a bad sensor. The compressor should cycle on and off. If it's staying on it will freeze up.
In the mean time you can try running it with higher fan speed and be sure recirculate is OFF.
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 06-27-2019, 03:11 PM   #10
I had a similar sounding problem with my F250. Dealer said it was a cracked evaporator and said it happened a lot with F250, 6.7s. Mine was still under warranty so it was corrected. It happened when we were on a trip and we were in DC on the bypass, middle of summer and very hot but the AC just was not working. I could hear ice falling when I stopped to fuel up sometimes but finishing that trip with no AC was not fun. Went to NJ and then returned to FL.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
johnruff is offline   Reply With Quote
Old 06-27-2019, 06:29 PM   #11
Lt Jim's Avatar
Thanks for all the suggestions. You've given me lots of things to check out when we get home.
Jim & Annie Fahrman
2011 F350 Turbo
DRW
Old 06-28-2019, 03:49 PM   #12
Lins's Avatar
Could be a few things as mentioned in here, but if it has a low temp sensor in the system that would be the first thing I would check if I was fixing it myself.
2007 Rockwood 2701SS
2014 Triumph Bonneville. NH Togas, TTP Tune 3
1953 GMC 9314
Lins is offline   Reply With Quote
air conditioner, ford
