Old 07-05-2013, 12:08 PM   #1
BigDTx's Avatar
Ford Expedition Break down
Just wanted to let any other members with an expedition tow vehicle know what I found out the hard way. Blew out the radiator on my 2003 Eddie Bauer 5.4 liter expedition with factory tow package on a trip for the 4th. Broke down in a small town and no one in town had a radiator. Ended up having my expedition and TT towed back home via two wreckers and one large bill. Once back to Houston I called the parts stores and no one had a radiator, everyone told me 3-5 days to get one. Now this is a common truck why is a basic part special order? I called 1-800 radiator who has a shop near me and its in stock for less money than the special order bs I heard. Guy at 1800radiator tells me when I pick up the part that he does a lot of work for the local ford dealer and said the thermostat caused the radiator to fail from over pressure. He was right I took out the old tstat and it was all corroded and stuck. Radiator guy said it happens a lot at 150,000 miles on these 5.4 motors. So you should check your tstat and avoid the problems I had and the expense. Also you will need a special tool to remove the trans cooler lines from the radiator. I tried 4 diff sets of quick release tools before buying a "lisle 39960 Ford trans oil cooler line disconnect Tool" For all 2003 and newer you must use this tool.
BigDTx is offline   Reply With Quote
Old 07-05-2013, 12:11 PM   #2
BigDTx's Avatar
Old 07-05-2013, 01:09 PM   #3
Wanna Be Camper
SaskCampers's Avatar
Thanks for the info and sorry to hear you had so much trouble getting running again.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 07-05-2013, 04:52 PM   #4
Oklahoma Proud
MillerTime's Avatar
Man that makes for a rough week. Glad you figured it all out!
I work at a large auto dealer and we use 1800radiator all the time. And yes those ford tranny lines are impossible without that special disconect on certain models.
Old 07-05-2013, 06:13 PM   #5
When my superduty still had its 5.4 I went through 4 radiators. They would split across the top tank.
Smitty3215 is offline   Reply With Quote
Old 07-16-2013, 04:49 PM   #6
BigDTx's Avatar
This one blew out the seal across the front of the top tank where it mates to the core.
Old 07-16-2013, 05:11 PM   #7
rattleNsmoke's Avatar
You have to drain and flush your coolant @ 50k intervals to keep the crud from building up. Ford may or may not use this service interval, but it's good practice.
rattleNsmoke is offline   Reply With Quote
Old 07-16-2013, 05:13 PM   #8
BigDTx's Avatar
I went one step further and traded it in on a new F150 4x4 😎
Old 07-16-2013, 05:27 PM   #9
Originally Posted by Danielflading View Post
I went one step further and traded it in on a new F150 4x4 ��
Should have gone 1 more step and got a Silverado 1500 4x4.
Old 07-16-2013, 05:31 PM   #10
Good choice. Since it's a tow vehicle, consider using your 'severe duty' maintenance schedule.
Old 07-16-2013, 05:31 PM   #11
TeresaInCAL
TeresaInCAL's Avatar
Good for you! Now you get to have fun!!
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
TeresaInCAL is offline   Reply With Quote
Old 07-16-2013, 05:45 PM   #12
At least you used your head and didn't buy a Chev junkpile!
Did you get an EcoBeast?
bakken is offline   Reply With Quote
Old 07-16-2013, 06:14 PM   #13
BigDTx's Avatar
Not enough torque in that so I bought a truck with more, Ecoboost 4x4! 😎
Old 07-16-2013, 06:15 PM   #14
BigDTx's Avatar
👍 Thanks
Old 07-16-2013, 06:16 PM   #15
BigDTx's Avatar
Will do, thanks!
Old 07-16-2013, 06:24 PM   #16
BigDTx's Avatar
Texas Edition!
Old 07-16-2013, 06:52 PM   #17
TeresaInCAL
Puuuuurdy!
Teresa
Old 07-17-2013, 10:35 AM   #18
iluvlcy's Avatar
Thanks for the info! We have pulled our trailer for 3 years with our Expedition and have been pleased with its performance. At 161000 we have made appt. to have temp gauge checked so we can avoid what you went through.
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 07-17-2013, 10:44 AM   #19
BigDTx's Avatar
I would recommend having the thermostat replaced and the system flushed out. Then you should be good. It's an easy DIY procedure to replace the tstat. Remove the old one, Then I put the garden hose on the tstat opening, removed the lower rad hose from radiator and turnec on hose and flushed it out. A lot of ugly stuff came out. Hope that helps!
