Old 07-05-2013, 12:08 PM   #1
BigDTx's Avatar
Ford Expedition Break down
Just wanted to let any other members with an expedition tow vehicle know what I found out the hard way. Blew out the radiator on my 2003 Eddie Bauer 5.4 liter expedition with factory tow package on a trip for the 4th. Broke down in a small town and no one in town had a radiator. Ended up having my expedition and TT towed back home via two wreckers and one large bill. Once back to Houston I called the parts stores and no one had a radiator, everyone told me 3-5 days to get one. Now this is a common truck why is a basic part special order? I called 1-800 radiator who has a shop near me and its in stock for less money than the special order bs I heard. Guy at 1800radiator tells me when I pick up the part that he does a lot of work for the local ford dealer and said the thermostat caused the radiator to fail from over pressure. He was right I took out the old tstat and it was all corroded and stuck. Radiator guy said it happens a lot at 150,000 miles on these 5.4 motors. So you should check your tstat and avoid the problems I had and the expense. Also you will need a special tool to remove the trans cooler lines from the radiator. I tried 4 diff sets of quick release tools before buying a "lisle 39960 Ford trans oil cooler line disconnect Tool" For all 2003 and newer you must use this tool.
BigDTx is offline   Reply With Quote
Old 07-05-2013, 12:11 PM   #2
BigDTx's Avatar
Old 07-05-2013, 01:09 PM   #3
Wanna Be Camper
SaskCampers's Avatar
Thanks for the info and sorry to hear you had so much trouble getting running again.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-05-2013, 04:52 PM   #4
Oklahoma Proud
MillerTime's Avatar
Man that makes for a rough week. Glad you figured it all out!
I work at a large auto dealer and we use 1800radiator all the time. And yes those ford tranny lines are impossible without that special disconect on certain models.
Old 07-05-2013, 06:13 PM   #5
When my superduty still had its 5.4 I went through 4 radiators. They would split across the top tank.
Smitty3215 is offline   Reply With Quote
Old 07-16-2013, 04:49 PM   #6
BigDTx's Avatar
This one blew out the seal across the front of the top tank where it mates to the core.
Old 07-16-2013, 05:11 PM   #7
rattleNsmoke's Avatar
You have to drain and flush your coolant @ 50k intervals to keep the crud from building up. Ford may or may not use this service interval, but it's good practice.
rattleNsmoke is offline   Reply With Quote
Old 07-16-2013, 05:13 PM   #8
BigDTx's Avatar
I went one step further and traded it in on a new F150 4x4 😎
Old 07-16-2013, 05:27 PM   #9
Originally Posted by Danielflading View Post
I went one step further and traded it in on a new F150 4x4 ��
Should have gone 1 more step and got a Silverado 1500 4x4.
Old 07-16-2013, 05:31 PM   #10
Good choice. Since it's a tow vehicle, consider using your 'severe duty' maintenance schedule.
