Old 03-29-2012, 12:58 AM   #1
TheFlagGang6's Avatar
Ford F150 Max Tow Question
Could someone who has the Ecoboost with Max Tow give me the maximum hitch capacities listed on the rear bumper and hitch. I'm primarily looking for what is listed for using a weight distributing hitch. The receiver tube on my current vehicle actually started to split at the bottom front. The seam in the tube was located where the weight distribution shank bears at the front. Thankfully I was checking my setup out before our first trip this year and found the problem. It's interesting that most if not all receiver tubes you see have the additional ring around the tube where you insert the shank, but nothing at the front to accommodate the condition when a weight distributing hitch is used.
TheFlagGang6
2008 Flagstaff 831QBSS
2005 Ford F150 FX4
2005 Ford Excursion Eddie Bauer 6.0l Diesel
TheFlagGang6 is offline   Reply With Quote
Old 03-29-2012, 03:39 AM   #2
dretired's Avatar
look at Fords 2012 F 150 towing capacity on-line
dretired is offline   Reply With Quote
Old 03-29-2012, 07:37 AM   #3
MtnGuy's Avatar
How about a photo fo the split ?? I have a 2006 F150, and want to watch out for potential problems.
Old 03-29-2012, 08:03 AM   #4
Triguy's Avatar
FlagGang,
While you are waiting for someone with the Ecoboost, is this what you are looking for? Looks like 1,130lbs is the max tongue weight...
This came from the Ford Towing Guide.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-29-2012, 08:08 AM   #5
My '10 F150 Screw with Max Trailer Tow has a bumper rating of 5000# with a tongue weight of 500#. My receiver is rated for 11,300# with a tongue weight of 1,130#. I am guessing the newer F150's are the same.
2012 Lacrosse 318BHS
2010 F-150 Max Tow
21C1 is offline   Reply With Quote
Old 03-29-2012, 09:06 AM   #6
acadianbob's Avatar
Mine says 11,500 and 1,150 WD right on the hitch. Just crawled under there and took the number right off of it.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-29-2012, 10:24 AM   #7
Unfortunately I did not take a picture of the crack/split but I'll do my best to explain it. If you drop your spare tire, climb under the truck, and look out through the receiver tube. On the bottom right corner of the receiver tube, a crack started where the bottom of the tube starts to radius at the corner. The crack had not opened up, but extended about an inch from the front end of the tube towards the back. When the tube was being welded back together, you could actually see the manufacturing seam as the heat from the weld built up and dissipated. It's entirely possible that this happened because of the location of the seam. If the seam was on the top part of the tube, it probably never would have happened.
I recommend anyone pulling a trailer to check your bolted hitch connections, but also take a look at major stress points. In my opinion the receiver tubes are relatively short for the amount of force they must resist when using a weight distribution setup.
TheFlagGang6
2005 Ford F150 FX4
Old 03-29-2012, 10:28 AM   #8
Thanks for the responses. I'm wondering if Ford designed a heavier hitch for these increased tow capacities. Might be something to watch out for.
TheFlagGang6
2005 Ford F150 FX4
Old 03-29-2012, 10:29 AM   #9
acadianbob's Avatar
I've always thought the same thing!
Old 03-29-2012, 10:35 AM   #10
MtnGuy's Avatar
Thanks, TheFlagGang5. I think my receiver tube is welded down the middle of the bottom of the tube, but I will definitely check that out.
f150
