Old 10-11-2016, 11:33 PM   #1
Ford F150 SuperCrew payload capacity
Advice? I'm in the market for a new (or new to me) tow vehicle and probably will buy a Ford F150 SuperCrew 3.5L Ecoboost 4x4. I'm getting the 4 door to carry passengers. To park it in my garage I have to stick with the 5.5' box. That limits the payload capacity to 2060#.
Our current trailer (21DK, below) has a GVWR around 5000#. We plan to upgrade but not to more than around 23' and 7000# (e.g., Rockwood 2304DS). We just don't want anything bigger.
We'll take that on trips including western mountains. I doesn't bother me if the gas engine revs up climbing high passes as long as it doesn't overheat and is operating within design specs.
With that in mind, am I correct in thinking the 2000# payload should be enough for a 750# tongue? Getting a 6.5' bed gets me another 800# but that's a lot of truck for what will be my daily driver in the city most of the time, and I can't park it in the garage.
As far as my payload is concerned it would be, at most, 700# in passengers, a 60# dog and couple hundred pounds in the bed. (Honda 2000 generator, gas can, and some personal gear.) More likely the passengers load will be half that.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 10-12-2016, 08:24 AM   #2
Tom
Seachaser186's Avatar
That would be the XLT with the 23 gal. tank, 7000 lb. GVWR. Mine has the 36 gal. tank with 1830 payload and I tow 7800 loaded. Need a good WDH with sway control.
Seachaser186 is offline   Reply With Quote
Old 10-12-2016, 08:29 AM   #3
acadianbob's Avatar
Look around the lot and check the yellow payload sticker on similar vehicles. I think you will find that most are nowhere near 2,000 lbs. More likely 1,500 to 1,600.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 10-12-2016, 09:05 AM   #4
KMP44's Avatar
My F-150 has a rated payload around 1800 and our Roo (23IKSS) is pretty tongue heavy, so when I weighed it loaded we were right at the max on the rear axle. Well under the max tow rating, but maxed out on payload, which is pretty common for a 1/2 ton. It tows, handles, and stops nicely - no complaints there. Personally, I plan to go with a 3/4 ton gasser for the next truck just to get the payload up around 3,000 lbs. Trade-off is its not an ideal daily driver, but I only drive about 15 miles a day for work.
I think for what you have now and what you think you might buy, you would be fine with an F-150 EB, but I would make sure it has the max tow package from the factory. The F-150's have a huge range of payload when you start looking at the door stickers.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 10-12-2016, 09:21 AM   #5
Tom
3 posts and already; the truck he is talking about it more than capable of towing this camper. He does not need a 3/4 ton truck.
Old 10-12-2016, 12:19 PM   #6
X2
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 10-12-2016, 12:26 PM   #7
Major Oz's Avatar
x3
....as long as it is the ecoboost....
2014 King Ranch Ecoboost Screw, 3.73.....2019 Palamino 27RLSS (customized)
Retired AF Mustang.....Picker always looking to jam.
Major Oz is offline   Reply With Quote
Old 10-12-2016, 12:29 PM   #8
f5moab's Avatar
Just wait....
f5moab is offline   Reply With Quote
Old 10-12-2016, 12:39 PM   #9
mike.t's Avatar
No one said he "needed" a 3/4 ton. One person mentioned he is going 3/4 ton next time.
2009 Ram 3500 Mega Cab
2018 Wilderness 2450FB
2014 Dodge Durango
"If you can't fix it with a hammer, you've got an electrical problem"
mike.t is offline   Reply With Quote
Old 10-12-2016, 01:26 PM   #10
Tom
And I mentioned the particular truck the OP was talking about was more than capable of towing that camper. He is talking about the 7000 lb.GVWR Package with the 3.5 EB and 2000lb. payload.
f150, ford
