04-24-2019, 09:54 PM
#21
Originally Posted by woo10-210
See post #2. The link is to the Ford Accessories website but Tasca will most likely have the best price. I buy most of my OEM parts from Tasca.
Wow that's a pricy camera
04-24-2019, 10:14 PM
#22
Now a "Top Member"
I got just the camera, and not the TPMS. I only paid $300. But even the whole kit can be had cheaper. I might add the TPMS later, but the camera is what I was after initially.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
04-25-2019, 12:04 AM
#23
Where did you buy it through
04-25-2019, 12:22 AM
#24
Originally Posted by dustin2004
The window sticker for the truck has option: CST TRLTPMS/CAM. It’s an xlt but I think they ordered it to be able to put the camera on it. But it doesn’t have the 360 cameras on it. I haven’t got the truck yet but I’m flying out to Washington on the 1st and going to drive it back to missouri.
I've heard Bo Beuckman Quality Ford is the place to buy from if you want a Ford. $12k to $15k off sticker price. And they're in Missouri.
2019 Silverado LTZ 1500 6.2L 10 Speed 3.42 Max Trailering Package
2018 Freedom Express 192RBS
2022 Highland Ridge Open Air Lite Range 17BH
04-25-2019, 02:10 PM
#25
TBarbs
I installed one on our 5th wheel and we are in our second season of use. Works good when backing into a parking spot. Edjunior’s info is spot on.
I ran the wires alone the I frame and up through the propane tank area into the storage area behind the tailgate. Fished the wire into the hitch and brought it out with the electrical wire. I used a high mount in the center in the back. When driving in rain or wet pavement the lens get dirty and down low that would, possibly, be worse than the high mount. How ever, it would be easy to wipe with a rag. The TPMS receiver I mounted on the metal below the propane tank and it works well there. Signal has never been a problem. Good Luck
2018 Wildcat 29RLX
2019 F-350 SRW Diesel 4*4
04-25-2019, 09:20 PM
#26
Now a "Top Member"
I got mine through a private sale on a Ford truck forum. A guy in Canada was selling it. I was a little worried about it, especially when it finally got here. The box was pretty beat up. But everything was there and it all works, so it was a deal for me. But this is the same thing from the Ford OEM parts site.
https://parts.ford.com/shop/en/us/tr...only-6450641-1
The description still talks about the TPMS, but this kit does not come with TPMS. If you want the whole kit and kaboodle, you need this one.
https://parts.ford.com/shop/en/us/tr...stem-6481461-1
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
04-25-2019, 09:22 PM
#27
Now a "Top Member"
I ran my wiring almost the exact same as you tbarb. Except I just ran it out the under the front storage compartment. I couldn't easily get through the hitch, and wasn't prepared yet to drill a big hole in my camper (which is why the camera is mounted where it is also!). It doesn't look quite as good, but it works well for me. I just need to clean up the wiring a bit, and get the 7/12 connector in the bed.
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
04-25-2019, 09:36 PM
#28
When you talk about 7/12 what are you meaning. I installed a plug in my bed will i have to change that one out?
04-25-2019, 09:39 PM
#29
Grammar Pedant
Can't view the camera while driving. That's a deal-killer. 90% of my Furrion camera's utility is while driving ... just brilliant being able to see back there for lane changes and such. I absolutely love my UTTC for the views when parking and backing up. But, I can't see paying so much money for a rear trailer camera that I can't use when driving. Pointless for me.
There's an expensive aftermarket system that will allow for it, but it's expensive and clunky. No thanks. For now, I'll stick to my Furrion.
Former RV: 2018 Rockwood Mini Lite 2504S
04-25-2019, 10:02 PM
#30
Now a "Top Member"
If you currently have a 7/4 pin plug, or just a 7 pin plug in the bed, yes, you will need to change it to have the 7 pin for the trailer lights, and the 12 pin for the camera.
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
04-26-2019, 06:54 AM
#31
I have the 2017 F250 and added the factory additional camera and TPMS to my 2017 Forest River Shockwave. I love it. Yes it works with sync 3 and shows right on your entertainment t screen.
You have to swap your 4 pin for the 11 pin the kit comes with but very easy to do.
The camera cable is wired so you do need to run it to the back of your trailer. I mounted mine on top looking down. Provides a great view while backing up.
I had the TPMS added to 4 trailer tires and should have bought the 6 vs the 4 and added the additional 2 to the truck and trailer spare.
Hope you enjoy it as much as I do.
04-26-2019, 08:07 AM
#32
I will sure be checking on our new 2019 XLT to see if Ford can add the 2nd camera & TT TPMS !!! I believe where I see others have a camera button, we have a button to cancel Start Stop Technolage ???
04-26-2019, 10:43 AM
#33
You will but it’s included in the kit I believe. Where you’ll run into trouble is if the wiring is long enough to reach the plug in the bed. That’s where the Nicholas welding linked earlier comes in. They make kits to put the plug in the bed. I’ve seen a few YouTube videos on there stuff and the kit in general.
04-26-2019, 08:52 PM
#34
Now a "Top Member"
Are you looking at a new truck now, or ordering one? If you get the Ultimate Trailer Tow package, it will be "ready" for the camera and TPMS. You can just get the dealer to add it, or if ordering the truck, make sure you add it to the build.
This is the Ultimate Trailer Tow package:
Keep in mind, this is not the actual trailer camera, this is just the 360 degree cameras on the truck. But it gives the ability to add the "Customer Placed Camera" and TPMS kit.
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
04-26-2019, 08:58 PM
#35
Now a "Top Member"
The plug that is included in the kit is meant to replace the 7/4 pin plug on the bumper of the truck. If you have the 7/4 in the bed, you should be able to replace it it with the one it the kit, but typically the in bed plug is just the 7 pin only. So the Nichols kit you refer to would be necessary. And it ain't cheap either, so be prepared to pay. But then again, nothing is cheap these days!
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
04-27-2019, 07:11 AM
#36
Attachment 202960
No we already bought the F-150, no Ultimate Towing Package, we are ordering a little Flagstaff 25FBLS, dealer will be installing a Trailer Camera, I am calling my Ford Dealer Monday for a price to install Ford Break Controller, and I will be adding a EZ Tire M S on the Trailer !!!
