02-18-2019, 06:51 AM
#21
This is what DH and I decided to use on our tow vehicle. Didn't take long to install them , after we figured out the trick of driving the pin thru the keeper first. If there is any noise from them I can't hear it.
https://www.autohaulersupply.com/cat...ock-553774.php
Not my youtube video, just the link that sold me on them
2013 Flagstaff 27RLWS - Chloe'
2019 Ford F-250
NC
02-18-2019, 02:12 PM
#22
Originally Posted by RandK-M
My Ram has similar hooking points and it is a pain in the butt sometimes with the size of the stock chain hook opening. I had to get it just right from the bottom up and put the hook in from the back to front, but if the angle wasn't right the chains are tight and making it hard to do. I ended up doing similar to yours but with a couple of these in a heavy duty version:
Attachment 197042
Yeah, that's the whatumacalit I'm using. Works great.
02-18-2019, 02:38 PM
#23
Careful with the add a link. Those need to get fairly large to achieve the proper rating. Usually to get the proper rating the links are too large to fit the tow chain. I ditched those a few years ago for this style. I bought mine at TSC.
https://www.tarpstop.com/chain-links...vis-style-5-16
Has a much higher rating at chain link size. As for the breakaway cable. Yes should be attached to the truck frame. I need to add something to the frame to hook mine on, not much back there to make it a easy fix. Right now I do as everyone else and it is on the hitch assembly. You would think the OEMs would add a breakaway hook point that is not connected to the bumper or hitch.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
2005 Jayco Bantam Flier
Hensley Hitch
02-18-2019, 02:39 PM
#24
On my 150 the only way to hook up is from down up.
you turn snap hook upside down, put it on the bottom of the hitch plate and hook it from behind moving up.
It works every time and I don't need a shackle....
To remove you turn the snap hook upside down, use your finger to open the hook and pull it down.
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
02-28-2019, 09:05 PM
#25
Shackle
Be sure to wire up the shackle so the screw doesn't back out. It's been known to happen.
Jim & Ann
Gladwin, Mi
2017 Ford F-250 Super Duty 6.2l
2017 PT Crusader 295RST
03-01-2019, 02:09 PM
#27
Had this same issue on an aftermarket Reese class 5plus receiver for an older Ford. Had a couple shackles laying around from HF. I leave the shackles installed and when I need to get out the tow strap to pull some one out of the ditch or get pulled out (lost my prop shaft cardan joint the same day of a snow storm).
03-14-2019, 11:39 PM
#28
I am using the same units....I think they are called chain mender links. I modified the installation on mine by omitting the center locks and using two shaft collars with set screws (I applied a small amount of Loctite to the set screw to ensure they wouldn't vibrate loose). This made it a lot easier to install them and much easier to remove them later.
06-07-2019, 08:57 AM
#29
Clevis Hooks - 2018 F250
I found that a product called Hammerlocks will do the trick nicely. They are about $22 each and can safely handle 12,000 lb chains
06-07-2019, 09:15 AM
#30
Had to do a similar mod to my Silverado 2500HD:
Funny that both Ford and Chevy couldn't design this properly.
2011 Traverse LT, 3.6L, FWD
06-07-2019, 11:49 PM
#31
Novice Travel Trailer Guy
Originally Posted by MT Biker
I only leave the hitch on the truck while towing, the second the trailer is disconnected I take the hitch off... because I am always the first one to walk right into it!
Ahhh glad I’m not the only one [emoji23]
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
06-08-2019, 05:31 PM
#32
Tractor supply seems to be a very acomodating store. When replacing my hitch ball, I need a very large crescent wrench but no store in town carried that size. At Tractor Supply, they didn't stock it either, but they had one back in their shop that they used. Said if I promised to bring it back, I could borrow it. Got my ball installed and brought it back a couple hours later. Great people!
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
06-08-2019, 07:34 PM
#33
Love that store. My dogs love it as well.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
06-08-2019, 08:06 PM
#34
The bad part of aging is when I can’t remember how I got the bruise. The grease could have come from anywhere.
Imgot tired of the bruises and the grease from the hitch, so I have started taking it off the tow vevicle and locking it in the ball socket. I thought that was pretty smart.
Then wife came back from laundry where the dryers did not work well. Best thing to do? hang jeans over the propane tanks and the tongue jack, right where the lower part of the legs met the grease on the E4 pivot sockets.
Now, I’ll think of buying another Hensley, at least the grease is contained. Lining up is a other question. At least when I had the Hensley, I had a good reason for shackles besides an oddball hole in the hitch.
Above poster is correct, shackles are far stronger than the threaded link. Ask me how I know. You could also get twisted shackles if angles are a problem.
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
