08-30-2017, 01:02 PM
Ford Upfitter Switches
OK, I have an F250 and absolutely love it except for the small fuel tank and frankly I need a bio break every 200 miles anyway. But those upfitter switches. They look great, all lined up there on the dash. Everyone that gets in the truck is impressed until they ask me what they do. "Well, nothing" is not an acceptable response. Anyone have any good ideas, useful or not
08-30-2017, 01:18 PM
I have used one of mine so far. Hooked it up to a power input for my back up camera on my Garmin RV 760 LMT gps. If hooked up to the back of the truck I plug the power into my back up lights. If I have my trailer hooked up then I move the camera to the rear bumper of my trailer and hook it up to another power port that I have powered by the upfitter switch. That way I can turn it on or off when I want to see the GPS or the camera.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
08-30-2017, 01:22 PM
08-30-2017, 01:23 PM
up fitter switchs
I have 2011 F450 and have added 2 electric cooling fans. I wired them to the up fitter switch's the fans work great in stop and go traffic on hot days
08-30-2017, 01:33 PM
Air compressor that I mounted under the frame of the truck to air up my Firestone air bags.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
08-30-2017, 02:06 PM
I like that idea, but do you also have a remote air pressure gauge? If not, how do you know when to turn it on and off?
08-30-2017, 02:50 PM
I have the fuel pump and solenoid for my aux fuel tank on an upfitter switch so I can transfer fuel. Because I hate the 26 gal fuel tank also.
2014 Ford F-250 4x4 CCSB Lariat 6.7 Powerstroke
2015 Puma Unleashed 351THSS
08-30-2017, 02:53 PM
Yes, I have a gauge mounted in my console.
08-30-2017, 03:19 PM
I have used all four of the upfitter switches on my F350 now. I have used them for air horns, TPMS, and additional cigarette lighter port and USB ports controlled by the ignition switch and dash camera.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
08-31-2017, 06:53 AM
I used mine for the air horns and air compressor. 1 switch used. If I flip it down, all is dead. Up and I have use of horns and air tank. Great to have.
08-31-2017, 07:12 AM
Don,t mean to steal the thread, but what air horns is everyone using? I want to be heard!
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
08-31-2017, 08:49 AM
Hadley with a 125# pressure tank and compressor.
08-31-2017, 09:22 AM
Used several on F350 for cameras, air compressor, generator start battery, extra lights in truck bed and extra power outlet (115 volt from inverter) to bumper.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
08-31-2017, 09:34 AM
Man I love this idea. My truck came bagged with the compressor. It automatically turns on to keep the bag pressure at whatever setting is set on the in-cab controller. The compressor is loud and it was annoying to have it start up every time the truck was started, so I pulled the fuse to it.
2015 Rockwood Mini-Lite 2306
2012 F-250 FX4 6.7 diesel
10k Equalizer Hitch
08-31-2017, 11:51 AM
2007 WildCat 32QBBS
1 is high idle (1200 rpm)
2 is a rear camera activation
3 is aux fuel pump to fill main from 91 gallon aux
4 is still open, for now
09-01-2017, 09:40 AM
Do you worry about forgetting it and over flowing?
09-01-2017, 10:02 AM
2007 WildCat 32QBBS
Yes. And I've done it. Because I do long drives without stopping & usually only turn it on when I'm below a 1/4, I forgot once that I turned it on but it wasn't for long and it only put out a mist because the main tank cap wasn't tight.
Usually if the gauge just begins to read full, I can let it run another 10 min until it's actually full into the filler neck. My transfer pump is 5/16 hose and a 5psi pump so in theory the pump will stall once the tank is full. (As long as your cap is tight😑
