03-30-2014, 07:52 AM
Forest River Salem 26TBUD Tongue Weight
Is 815 lbs to much tongue weight for a 2005 Chevy Tahoe 2WD? The max tow weight I believe is 7700lbs and I'm not sure why, but I have stuck in my head the max tongue weight shouldn't exceed 10% of the TV capacity. My TV came equipped with a "tow package" not sure if that affects the weight or not. I really like the 26TUD Bunkhouse, but then I see the 27' bunkhouse and it has a lighter tongue weight, but only 2 bunks.
03-30-2014, 02:06 PM
HECK YEA!!
realistically, that real world tongue weight will be nearly 1000lbs.
first, you need to look at your owner's manual, which should give you a max hitch capacity. DON'T go by what's stamped on the hitch receiver, that's the receiver's rating, not your Tahoe's rating.
second, SUV's have extremely poor payload amounts. the trailer's hitch weight comes out of that, along with the weight of the WDH, cargo and anyone in it other than a 150lb. driver.
payload should be on a sticker on the driver's door edge. according to Edmunds, the Tahoe's max payload is only 1525lbs.(VERY poor) so, that leaves you only 425lbs., after subtracting the hitch weight and WDH weight, for passengers and cargo.
third, don't assume that it can tow 7700lbs.
you need to post rear end ratio and which engine, the 4.8 or 5.3?
03-30-2014, 05:19 PM
So what would be an ideal tongue weight then? That's to much math for me The Tahoe is a 5.3 with a 3.23 rear end ratio
03-30-2014, 06:29 PM
are you sure it's a 3.23 rear end?
should be 3.73 if it has the factory tow package.
03-30-2014, 07:28 PM
That's on odd axle ratio, the usual is 3.42 or 3.73. The Tahoe is similar to the Suburban I have, so you could do max 1000lb TW per the rating of the hitch, but you need to check all the weights especially the rear axle weight as Dan said since payload on a half ton especially an SUV is limited.
A dealer can run your VIN for the GM build sheet and you can see all the ratings on it, since you may not have a typical model of the Tahoe.
The HD tow package I got gave me better cooling, alternator, hitch and wiring etc. but it still has the 3.42 rear axle.
2009 Suburban LT 1500 - 4x4 - 3.42
2009 Flagstaff 23FBS Super Lite
Nights Camped in 2015 - 21
Nights Camped in 2014 - 29
Nights Camped in 2013 - 31
03-30-2014, 07:50 PM
We towed a TT that weighed 4,000lbs, 4 point WDH, believe me when I tell you that if your going bigger than that don't be going far from home, we did it a few times and moved on, we do travel up to 6 hours from home. Ours was an 03 Tahoe, 2WD, tow package, 5.3 now we got out of that and bought a "REAL" TV, then we were able to get the trailer we should've got in the first place. Just some advice, get the TV, then get the RV.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
04-01-2014, 05:36 PM
I checked the VIN Decoder website online and it says its a 3.23 gear ratio (GU5). thanks for the info beerjay, I only wish I had the 09 for the extra gears in the transmission And crusadernoob, I only hope to get a Duramax one of these days. If only they had that in a Tahoe!
04-01-2014, 10:34 PM
I bet a cookie and I rarely bet, that the big 3 or 4 will have diesel SUVs next year. If GM survives the latest MBA mess.
Yes I like the 6 speed in the 2009 over the 4 speed I had in my 2005 Suburban. Now for LT tires ... Tow-haul is a great toy too, but hills and wind are a bear towing a TT.
