Frame mounted drag casters
Have benn trying to figure out if installing frame drag casters would be a good idea or not. Currently to get out of my driveway I need to leave the WD unhooked and remove the jack pad from the power jack at the hitch. drive down driveway pull into the cul-da-sac and hook up the WD. If i have a full load of fresh water I need to do this plus go over a 2x10 just before the hitch touches. If i leave the WD on then I need to drive the trailer on 10 foot 2x10 boards to keep rear stands and bumper from dragging. My concern would be if one drag caster takes on more load then the other. What effects would it have to the frame, walls, flooring and so on. I believe mine will hit at almost the same time but what about gas stations and uneven entry pads to places. Is anyone else using any? My trailer does have the rear stabilizer protectors to keep from ripping them off. Has any one used those removable stabilizer jacks?
