Old 07-09-2014, 08:50 AM   #1
Freestar M-108 tires
Anyone have any experience with these tires? ST205/75/15. Got a pretty good price on them from a dealer that I trust. Load range C which is 1,820 per tire so that gives me 3,640 per side or a total load of 7,280. Am I calculating that correctly? My rig is about 5,400 loaded with empty tanks so it would seem to be well within the weight rating of the tires. Reviews are good/bad depending, but so are the reviews on the GY Marathons.
Skippy38 is offline   Reply With Quote
Old 07-09-2014, 09:47 AM   #2
DaveSchwartz's Avatar
If that is a measured weight, then it is 74% of the tire set maximum and I would not be worried. I remember your previous thread and had looked up the specs on that camper as having around 7000lbs gross on the tires. Since the dry weight on the tires would be around 4000 then I guess you could be at 5400 loaded.
My previous TT had Chinese 'Nanco' tires and after a very early failure (which was, I think, due to rolling off the bead in a sharp turn backup) the spare plus the rest of them lasted 9 years until I traded in the trailer.
Just be sure to check for 50psi cold at the start of every trip.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 07-09-2014, 10:29 AM   #3
kho6658's Avatar
My tt came with them. I just replaced all 4 after the first year. They started to show signs of cracking around the tread.
Sent from my SPH-D710 using Forest River Forums mobile app
2016 Freedom Express 28SE
2017 F350 Lariat
Days Camped 2018 - 6
Days Camped 2017 - 41
kho6658 is offline   Reply With Quote
tire, tires
