07-23-2016, 01:08 PM
friction sway bar
I 'm new to towing and hauling a 13 Shasta Revere 27bh with an 08 F150 5.4 Lariat 3.73 With tow package.Using a Husky WDH with 1k bars and Pro Series sway bar. My question is that Pro Series doesn't give any guidance as to how much to tighten the sway bar.I've been keeping it fairly snug but sometimes get a very occasional sway. should I crank it good and tight? anyone else use these and if so how tight. Thanks
07-23-2016, 01:23 PM
Friction sway bar
When I was using a sliding friction type sway bar it seemed to be a simple trial an error method of adjustment. Snug it up good and if it sways more than you want tighten it some more at the next stop. Not sure you can ever get all the sway out with a sliding bar but I was able to make it comfortable to tow.
(note: mine had two adjustments on it, one was a hex nut for course adjustments and the other had the handle welded to it for fine/quick and adjustment.)
My new Trekker Hitch has built in sway control that you can and just with a torque wrench, I still use the old method of tighten it up and adjust as needed until I get the trailer as stable as I am comfortable with.
2016 Rockwood Ultra Lite 2604WS (Emerald Pkg)
2015 F350 Superduty Powerstroke.
Trecker WDH Hitch
Lazyboy Recliner replaced Back two chairs.....
07-24-2016, 07:52 AM
Those slider bars are ehh and a oain to adjust as you have found out. My buddy tried everything with his Pro Series w/ slider and finally stepped up to the Husky Centerline TS. That thing is amazing. With th old setup he was white knuckling all the time. This new Husky makes it a breeze to tow. May want to look into that. Very cost effective as well. He went with the 12k/1200lb bar setup. His trailer is about 8500 but wanted room to grow.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
07-24-2016, 08:06 AM
The "Friction Bars" require you "Tighten by Hand/Bottom out" the lever bolt! I would also think if your Set up requires 1000# Bars that you would use (2) Friction Bars also! Youroo!!
07-25-2016, 11:47 AM
like others have said - it takes some trial/error to figure out how tight.
but let me caution you - don't go too tight.
My old trailer had a similar setup. One one trip I got it too tight (it pulled great!) and when I got to the campground I found that I had bent back the small ball that the sway bar attaches to.
Luckily I was able to find a machine shop in that town... for a small fee they bent it back and welded it with an extra piece of steel to support it better.
(I would not be comfortable doing this with the towing ball, but this was just the sway ball)
07-26-2016, 02:12 PM
First: actual sway bars provide much, much more sway control than the "sway control" feature built-in to the WD hitches (Reese SC, Reese dual cam, Equalizer, Husky Centerline, etc.).
Second: people tend to not tighten the sway bar enough. I tighten mine as tight as it will go... on my 38' TT.
Third: a second sway bar is recommended for long TT, like mine (although I only run with one).
The friction and leverage of a sway bar far exceeds that of the WD systems. Plus, they are easy to replace if/when they get worn out.
07-26-2016, 03:08 PM
Right. Turn the on/off handle until you can't turn it anymore, which indicates it is fully bottomed out against the main body. If you need to make adjustments, don't fuss with the handle. Make adjustments with the adjuster bolt, which is a few inches from the on/off handle. Make adjustments in 1/4-turn increments, then do another test drive.
In my opinion, if you flick the steering wheel, and the trailer swings 1 way, then a smaller amount the other way, then settles back straight, you are good. Oscillation more than once in each direction means you should tighten 1/4-turn and try again.
07-26-2016, 03:18 PM
I run a friction sway control on my 32' TT and never had any issues. Right now I run 1 on the drivers side and ran from CT to VA Beach with no issues. Though I do have a second one for the pass. side, just never put it on yet.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
07-26-2016, 03:30 PM
This is not a factual statement...it is an opinion...and an overblown one at that. There are too many advantages for using a WDH with sway control built in not to consider them...but one of the disadvantages is NOT lack of sway control for a well tuned WDH...no matter which WDH with built in sway control is chosen.
Flame on...
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
08-14-2016, 09:05 AM
Flame on...
It is factual. The sway control built in to the weight distribution system relies on pressure from the bars, which can be a lot... but not near the same as the clamping force of a sway bar.
I never said to not consider a WD system with sway control... and I certainly didn't advocate not using a WD system. However, a sway bar controls sway much more. I've used WD systems without built in sway control both with and without a sway bar and I have used WD systems with built in sway control both with and without a sway bar. No flame intended, but I stand by my comments.
A sway bar provides more friction through its clamping force and more leverage than the built-in sway control of WD systems.
I use both.
This post of course is not discussing the Hensley type systems. Those are a different animal.
08-15-2016, 11:37 AM
Technically speaking, it would be difficult to judge this without seeing both systems and making measurements of the actual forces.
All sway control systems work by apply force that prevents the trailer from pivoting about the ball.
Friction based systems use clamping force on a friction material to resist any change in trailer angle.
Non-friction systems use camber angles in the WD bars to apply a force to keep the trailer straight.
Whether the friction force is higher or not would of course depend on the setup and design.
(FWIW - on my 2 data points, which are different trailers, the SwayPro hitch performed much better than friction sway control on my old hitch. And this trailer is bigger and heavier than my old trailer...)
08-15-2016, 06:25 PM
Thanks for all the great tips pulled a few more times since and seem to have found the "sweet spot" in tightening it.Thanks
08-23-2016, 02:17 PM
Yes, too many variables to say that friction sway control will always provide more friction than any integrated system. Friction sway controller is a strong clamp for sure, with friction material on both sides of a large surface-area bar. But most integrated systems have smaller friction points at multiple points, at both ends of both bars.
I used to tow a large popup with minivans. Used a 400 lbs rated Single Bar WDH, plus a friction sway controller. Lots of others with similar setups liked the "mini-350" WDH, which had integrated sway control. I never switched, because what I had already worked so well. But when I went to a larger vehicle and camper, and needed to get a new WDH anyway, it only made sense to go straight to something with integrated sway control. Works as a system, takes less time to set up, etc, etc.
08-23-2016, 02:45 PM
... This post of course is not discussing the Hensley type systems. Those are a different animal.
Indeed they are. The Hensley and ProPride hitches do not use friction sway control because the design prevents sway from occurring.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
