Old 01-26-2013, 10:04 PM   #11
SYE
SYE's Avatar
My 2500HD started sagging when I bought my new 5er, My old one was almost 400 lbs less hitch weight. I was looking into air bags but I was not quite sure i was not convinced as to everyone that has had them that I know around here say they started leaking within the first year or 2. After doing much research I have decided to go with the Roadmaster Active Suspension Roadmaster Active Suspension Kits | Helper Springs | Overload Springs I think this will help with my problem, there is a review on youtube and check it out before you make your decision. I found them for 315.00 including shipping. i hope this helps.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 01-27-2013, 07:04 AM   #12
Toy-aholic
Originally Posted by TTNewbees View Post
Guys/gals,
We currently have a lacrosse 303rkd TT. When hitched to the truck (f250 psd) it sags a little and has been adjusted by dealer after weighing the tongue at 1279 lbs loaded. Honestly it sags more than my Yukon did, which had auto ride suspension and would pick up the back end. The setup tows excellent but the sag bothers me visually. What is the best option to correct this as we are investigating 5ers and I am not sure if this will get better or worse with a 5er. What I have looked at has a pin weight less than 2k.
the leverage of a bumper tow is a whole lot greater than a 5er therefore more apt to sag
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 01-28-2013, 07:17 PM   #13
mhuffs9017's Avatar
We had to put the bags in for the sag. We have the same TT as you and the same TV. It helped tremendously. Truck rides very level now with as little as 10-15psi in the bags. We recently just bought our 5er so we are anxious to see what it will take to keep the rear up.
2013 F350 DRW 6.7 3.73 - Lariat Ultimate FX4 - Tuxedo Black - 14K GVWR
2013 Sabre 36QBOK
2012 Rinker 246BR - "Off The Grid"
Nights Camped 2013 - Not enough!
mhuffs9017 is offline   Reply With Quote
Old 01-28-2013, 08:08 PM   #14
Denver, CO
garbonz's Avatar
The road masters are great. Install them and forget them.
2017 Fuse 23T
Old 01-28-2013, 08:18 PM   #15
Denver, CO
garbonz's Avatar
Roadmasters
Here is a pic w our new vcross platinum
2017 Fuse 23T
Old 01-28-2013, 08:19 PM   #16
Denver, CO
garbonz's Avatar
Whoops. We are defying gravity. Donno how that happened
2017 Fuse 23T
