Old 06-09-2019, 06:01 PM   #1
Front and Rear Axle Weight
Went to the CAT scales to weigh just my TV with my E2 hitch on with no bars, DW and my son... TV loaded as if we were going to hook up and go.
I need opinions on numbers. Went through twice just to see if everything matched up.
Steer Axle: 3520 (GAWR 3950)
Drive Axle: 2560 (GAWR 3950)
TAW: 6080
Do these numbers look correct for unloaded. The rear axle looks low, but I donít have anything in the bed of the truck either. Let me know your thoughts please!
Infinite_Enigma32 is offline   Reply With Quote
Old 06-09-2019, 06:17 PM   #2
You need the weight of the tow vehicle without the trailer to know if your in the ball park on weights. Looks like you might have a little too much weight off the rear of the truck though.
ardakota is offline   Reply With Quote
Old 06-09-2019, 06:22 PM   #3
fonzie's Avatar
If this is only the truck (no trailer attached), then your weights looks OK.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-09-2019, 06:25 PM   #4
Daycruiser's Avatar
Yes, they look fine.
44 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is online now   Reply With Quote
Old 06-09-2019, 06:27 PM   #5
This is without the TT attached. Everything but the TT.
Old 06-15-2019, 01:59 PM   #6
Finally weighed the whole rig.... here are the numbers:
TV curb weight - 5591 (7200 GVWR)
Payload - 489 left out of the 1609 with everything added (WDH, Occupants and gear)
Steer Axle - 3320 (3950 Max)
Drive Axle - 3560 (3950 Max and 1000 pounds transferred back with the WDH)
Tandem Trailer Axle - 5660 (3500 Max on each)
Total Axle - 12540 (15000 Max)
How do you think all of that looks?
axle, weight
