Old 01-24-2016, 09:10 PM   #1
Bravo67's Avatar
Front sharp radius caps on FR 5th wheels
With are soon to be new FR Heritage Glen 337BAR,on the front end of the trailer we noticed the new design called a "sharp radius cap front end".My question is has anyone used a fixed hitch without a slider with it and how is the clearence to the rear glass on the truck.We have a 6ft bed.
Bravo67 is offline   Reply With Quote
Old 01-25-2016, 09:55 AM   #2
Jim34RL's Avatar
I have always stated that there are two type of people who pull with a short bed truck and pull a 5er! Those that have hit the cab and those that will!
I have a 2008 Ram Mega Cab with the 6.5' box using a manual sliding hitch, this has been used in two different short bed trucks. I have pulled three different 5er's, all with extended kin pin boxes and two of them have had the rounded or 88 DEG's corners on them. If I did not manually extended the slider hitch when turning really sharp to get into a narrow camp ground site or into my driveway I will hit the cab of the truck with the trailer. In normal day to day driving on highways and city streets I do not need to extend the hitch and I can pull the 5er with no issues. It is only in real tight turning situations that the hitch needs to be extended.
My first trailer was a 2006 Ameri-Camp with an extended pin box this had a radius front end but not enough clearance with the cab. My next trailer was a 2010 318SAB Cougar with the 88 DEG corners, this two would hit the corner of the cab in a really tight turn. Our current trailer a 2016 34RL Cedar Creek will hit also in a very sharp turn.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 01-25-2016, 12:28 PM   #3
TURBS's Avatar
I've had my manual slider for 6 years and have "yet" to engage it.
There will be a day.
Ps don't cheap out on the hitch, buy the good one first.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 01-25-2016, 08:33 PM   #4
Tfort's Avatar
I can make almost a 90 degree turn on mine without hitting. If you get into tight turns when backing you have to pay real close attention or you can push it to far. I have to cut it real hard to get into my driveway but the cab clearance is the easiest to watch as long as you remember to watch it.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 01-25-2016, 08:41 PM   #5
Crusadernoob's Avatar
Our short bed, with a low profile over the bed rail tool box, haven't been close to either one, yet. No slider.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
Crusadernoob is offline   Reply With Quote
Old 01-25-2016, 08:56 PM   #6
tkmi's Avatar
Have drove a truck for 43 yrs. If you go past a 45 to 50 degree back up, you already lost it. Start over. Its all on how you set up to start.
2013 Silverback 33RL
2010 2500 RAM 6.7L
tkmi is offline   Reply With Quote
Old 01-26-2016, 01:08 PM   #7
sfsgm's Avatar
About your low profile tool box
I've been researching low profile boxes for my F-350. I pull a 31 foot Forest River Cardinal.
What box are you using and how much clearance do you have when you are turning on level ground?
sfsgm is offline   Reply With Quote
Old 01-26-2016, 01:18 PM   #8
I bought a deep, low profile Kobalt, used. I wasn't sure it would work so the $100.00 I spent on I could get it back. Best thing I did, no tools in 5er, under my seat. Clearance in a turn as sharp as my truck will turn is at least 6" I would have to jack knife backing in, the trailer twisting opposite of the truck to hit it. Never gonna happen.
Old 01-26-2016, 04:08 PM   #9
I use a non-slider on a short bed but the reason I can is because of the pin box which is a Reese Revolution and it swivels so a slider is not really needed. The pin sticks is more forward compared to some of the others. If you have this pin box you may not need a slider.
-Craig Bean
2015 Rockwood 8289 WS
2003 Dodge Diesel SB
CraigBean7672 is offline   Reply With Quote
Old 01-26-2016, 06:30 PM   #10
Have the 6.5' bed and non-sliding hitch and have in some tight places without any issues. Also have an over the rail tool box that thought might have been a problem but so far so good.
Steven & Tiffany
2015 Crusader 296BHS
2013 Chevy 2500HD LTZ CC Z71
Camp as often as we can
Steven379 is offline   Reply With Quote
Old 01-26-2016, 07:03 PM   #11
rracer5's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
X2. And as tkmi says, just start over.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-26-2016, 09:20 PM   #12
Have an Andersen hitch in a GMC 2500 HD 6.5 ft bed. No problems turning and no slider needed.
Mahlstedtd is offline   Reply With Quote
Old 01-27-2016, 09:08 AM   #13
phil falls's Avatar
Red face Reese Airborne Side winder
I have a 2011 Dodge Ram 3500 Dually Mega Cab. I pull a 42' Dynamax Trilogy.
When I bought this unit, I had it priced with a Reese Airborne Side Winder pin box. I have tested the clear turning radius and am able to go past 90 degrees and still not hit the cab. Also, this type of pin box makes the trailer follow more closely to the truck turning radius. Meaning you don't have to leave a much room or swing out as far to make a turn.
I love it and will always have a Reese Airborne Side Winder with any future 5er I buy. Good luck and happy trails.
phil falls is offline   Reply With Quote
Old 01-27-2016, 09:31 AM   #14
TURBS's Avatar
As far as mine would go without activating slider on my last 5th wheel.
2015 Columbus 320RS
2008 2500HD Duramax
Old 01-27-2016, 09:53 AM   #15
When I bought my Dodge witth a 6 1/2 foot bed my dealer installed a slider. He said I probably would never need it but better to be safe. I had never had one and forgot about it. My third trip I found out he was wrong!! I didn't take the back window but came very close! I now have a nice dent in the corner of my cab to reminddddd me I have a slider and SHOULD USE IT!
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 01-27-2016, 09:54 AM   #16
It is not possible to hit the cab with the Reese Revolution and my shorted F250.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
Mtelkman is offline   Reply With Quote
Old 01-27-2016, 10:12 AM   #17
rracer5's Avatar
2015 Columbus 320RS
2008 2500HD Duramax
And that ain't easy in a barnyard THAT big!!!!
Old 01-27-2016, 10:29 AM   #18
AquaMan's Avatar
Is that where I'm gonna park the GTown this summer?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
5th wheel, wheel
